Question about Photography
Minolta HiMatic 7 34mm camera
Shutter will not function/stuck.
Leaf shutter needs to be free from oil and dirt and not damaged. needs to be cleaned with a solvent. everyone i have encountered uses ronsonol to clean - but first you have to get the camera apart. on some range finders there is a way to manually close the shutter, then you can put a few drops of the solvent on it and try and fire the shutter a few times... good luck - and look up info on "cleaning leaf shutter" if you want more info
Posted on Apr 04, 2009
Shutter Curtain Doesnt Reset Mirror
If your shutter curtain doesnt close, it may be out of Sync with the shutter button. My Minolta x700 had this problem. My camera guy fixed it for me with a couple of tinker moves. Contact your nearest camera repair shop (if available) and ask how much it would be to fix the Sync between depressing the shutter button and the curtain. it may just be some grime that has it stuck.
Mar 18, 2014 | Minolta X-700 35mm SLR Camera
Minolta 700 film advance lever was working, then it wouldnt wind, now it is stuck.
Use or buy a brand new battery from store that sell lot of them.
Do not get from store that only has a few, meaning they have been sitting there for years.
atdlee@netzero.com
Feb 14, 2014 | Minolta X-700 35mm SLR Camera
I have a Minolta XG-A camera, and i can take a picture but the shutter is stuck?
My shutter does that when there is low light, or just slow shutter speed. You could try changing those settings, otherwise, last time mine got stuck, I loosened a screw on the bottom right under the shutter release button and the shutter just snapped back into its place.
Jun 09, 2012 | Minolta XG-A 35mm SLR Camera
Film advance stuck and metering problem on Minolta X700
Hi, i have the same problem, do you fix it?, can you give me the solution please?
Thanks, my mail is dg_alex_vargas@hotmail.com
Jan 27, 2010 | Minolta X-700 35mm SLR Camera
I have a jammed shutter on my Minolta 400si SLR. It also has caught shutter curtains. I noticed this the moment I received it from an ebay seller. The shutter won't open beyond 1/4th of the way. No...
With the shutter curtain out of place the camera will not function. If it is only out a little you may be able to persuade the shutter blades to fall back into position. If you bend them, or if they are out of the proper tracks then the camera will have to be sent to a repair service for repair.
Nov 23, 2009 | Minolta Maxxum 400si 35mm SLR Camera
Film Advance lever stuck
When you press on the shutter release does it "click"? A few hard taps with the end of your finger onto the shutter reelase button may unjam it if it is stuck...
Jun 15, 2009 | Minolta X-370S 35mm SLR Camera
Stuck shutter, and I can't advanced the film
There are one or two capacitors which go bad and cause the shutter not to work. Just google "Minolta shutter problem", and you'll find details instructions on how to replace these...I believe the defective capacitor on your camera is accessible by removing the bottom cover.
Jun 10, 2009 | Minolta X-370S 35mm SLR Camera
I am looking for the owner's manual for a Minolta Himatic 7s
hi
check this out
www.in.lge.com/XCanvas/images/42PX3RVB-ZA.pdf
else try this
www.butkus.org/chinon/minolta/minolta_hi-matic_7s/minolta_hi-matic_7s.htm
i hope ur problem will be rectified soon
all the best
Mar 10, 2009 | Cameras
Photography Logo
542 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
