Question about Toshiba Televison & Video
Toshiba Regza 37'' 37X3030DB occasionally retunes two of it's TV channels from UHF channel 60 (good signal)to UHF channel 45 (poor signal) for no reason. All other channels are unaffected. Auto updated is off.
5 Suggested Answers
james klgr
  • 362 Answers
SOURCE: toshiba regza
the best thig and easiest way would be to reset everything and start overthose things have so many differnt settings but to start turn it off then on the right side it has a power button, hold that power button down for 5 seconds and its reset.
Posted on Dec 14, 2007
  • 301 Answers
SOURCE: Toshiba 50hm66 Sound problem on CBS channel only
check any SAP settings in the menu
Posted on Mar 31, 2008
SOURCE: JVC tv model HD56G786
this isn't solution
Posted on Sep 12, 2008
SOURCE: No BBC 1 or 2 after digital switchover.
I have the same box and re-tuned mine with the same results as you.However i discovered that the NEW BBC channels were on the channel guide list starting at channel 800
Posted on Jul 02, 2009
SOURCE: Retuning digital TV
You need to use the (what looks like a large sattellite) button to retune your tv.
Some Samsung tv's let you access the button but other models have a "D MENU" button on the remote. Press this button, then scroll down to the icon that looks like a large sattellite. Then scroll across and click on "Auto Store" this will then go through all the available channels
Posted on Sep 30, 2009
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
Toshiba regza
You may have power supply trouble
May 14, 2013 | Televison & Video
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Is my REGZA 42" 42HL167
This REGZA 42" 42HL167 has ATSC digital tuner built-in. when you set the TV to scan for channels, you must set the source to AIR, not CABLE. Since the Digital TV signals use the Old UHF band for transmission, your amplifier is made for this band? Try it without th amp first.
Please leave rating if it helps
Jan 31, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
How to connect settop box to tv with no avs
You will have 2 UHF plugs on your set top box.. One for input (aerial) and 1 for output (TV). Connect your main aerial to set top box UHF input and connect an Output UHF lead from set top box to TV. Next switch on set top box and retune tv on a spare channel until you get set top box channels (good idea to switch on menu on set top box so you know you are tuned into set top signal )
Feb 12, 2010 | Philips Televison & Video
VHF channels come in however UHF channels are not
uhf and vhf tuning is performed in one board(tuner brd) there are some on line part stores that can help you with the number and price, you'll need to provide the model number. partstore.com is one of them, but there are more.good luck.
Jan 09, 2010 | Vizio GV46L 46 in. LCD Television
How do I retune a Toshiba Regza 32AV615DB 32-inch when I select retore defaults nothing happens
what are you trying to do ?
if your trying to re scan your channels then go into youe setuo menu and rescan channels in cable mode if your on cable or antenna select air
Dec 02, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Retune for channel 5
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Sep 30, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Televison & Video Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
