I had similar connection problems as mentioned in this post (TV finds the AP but when I try to connectit fails). Not sure what to do.. I have a Belkin router (share) and have managed to link other computers and the Wii but can't link the LED TV.
Hi there.
I assume that you are connecting wirelessly. The most common problem is that the TV is at the outermost range of the wireless signal from your router/AP. try moving the router/AP closer to the TV. However I would recommend that you use a lan cable rather as this is a more reliable connection. You will also need to check your network settings. To keep the network connection more stable make sure both the TV and media server have static IPs, especially the server.
Sometimes these types of issues are difficult to troubleshoot remotely (in this case, you've got 4 potential points to address: TV, dongle, router and ISP.)
If your TV and/or dongle utilize specific ports outside of the "norm," you may need to manually configure your router to allow for this.
Depending on the distance your AP/router is from the TV/dongle, the signal may not be strong enough. (Or, the signal coming from the AP may be present--you can confirm this with another wireless device--and maybe it's just the dongle itself has a poor range.)
Also, the dongle itself may be defective. Generally, there issome form of configuration that needs to be done, one way or the other, either on the computer, or on the TV itself (like a setup option).
Most likely, it's not an ISP-related issue.
Also, try to contact Sharp Technical support. They should be able to give you some recommendations that may prove helpful.
If all else fails, see if you can track down one of the dongles listed as being compatible in the TV manual, or find a dongle that's advertised as being compatible with your specific television, as that might be your best bet.
I'm having a very similar issue with 5 MSM410's (at 2 differant locations), purchased at the same time, from the same vendor.
With 2, when connected using PoE Injector, the AP gets hot (at the Data/Poe port), and only permits 3 devices to connect before the devices start losing the ability comminicate beyond the AP (i.e. I can logon to the AP with the Web Interface (WI), but cannot ping the DHCP server or even the Gateway device on the other side of th AP from the devices, but can ping both directions without issue from the AP's WI). HOWEVER; when connected using the PoE from a Cisco ASA-5505 (port 0/6 or 0/7) the devices work flawlessly.
- For this site, I replaced the Power Injector first, then replaced the AP. No change
- When connected to the PoE on the Cisco the unit does not run "Hot".
With 3 others at another location, they only allow 3 devices to connect and will disconnect any devices previously connected. These 3 are supplied PoE from Dell PowerConnect Gigabit Switches (also used to supply power to the VoIP and PoE Security Camera's), and also run Hot at the Data/PoE ports. We have not tried power injectors at this site.
I've tried to find any indication of how to adjust the PoE and Data Port settings to resolve this, but cannot find anything, and this appears to be a unique issue, as noone I have contacted has ever experianced it.
If you have the original TV remote there should be a button that has Input or I Select or something similar. You need to press that button when you have the Wii turned on to find the right input it is connected to. There more than likely L1 L2 AV1 or AV2 or Front AV or something similar that your Wii is connected to. Or sometimes just going Channel Down past channel 3 will get you to one of the inputs I mentioned.
What worked for me was to go into SETTINGS then NETWORK SETTINGS select CONNECTIONS then click your routers name then scroll down to NETWORK KEY type in your password and then SAVE then try connecting! hope it helps!
I had a similar problem and solved it this way:
Go to Start > All Programs > (the name of your USB adapter). In that folder there should be a "manager" or some type of program. Run it. One of the settings should read "AP mode" or "Station mode". When I switched from AP to Station, suddenly a list of available networks popped up. And my problem was solved.
Hopefully that will work for you too.
GregM23
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
A suggestion to a similar post @ http://www.fixya.com/support/t187720-no_sound
If all else fails, you may want to try the "thump test" this will help you determine if its a loose/cold solder problem inside the TV. Give your TV a good whack at the side, top or back, if sounds comes on even briefly, it's a loose/cold solder problem, if not then you probably have to have the unit serviced by a qualified professional.
The "thump test" is not a recommended action. Most techs would not even mention it but somehow it is performed (whether deliberately or not) by most.
If verified that sound is faulty due to loose or cold solder, then it is a simple matter of locating the fault and resolder.
Hope this be of some help/idea. Post back how things are or should you need further information.
Good luck and kind regards.
On a similar model, the advertised range is anywhere from 50-100 meters outdoor or open air. Inside the house or within the office, the walls, doors, drapes, furnitures etc obstruct the signal and brings down the range to less than half.
What we have tried to improve the signal range:
1. Install the AP/Router high up not just on top of a closet or cabinet but really high, about a foot from the ceiling;
2. Approximate the very center of the various locations of the laptops and install the AP/Router there;
3. Disabled and did not use security WEP, WPA but turn MAC Filter on;
4. Use an external hi-gain omni antenna;
5. Install a second similar unit at the farthest coverage and run it as a repeater;
6. Replace the AP/Router with the new N type (which again claimed to be 4X wider and 12X faster) which made us go back to step 1.
It's a love/hate experience and we ended installing more repeaters. But it works.
Hope this give you an idea or two (but hopefully not the frustration nor the headache). Post back how things worked out your end. Cheers
