Question about Audiovox Televison & Video
It won't press the button even though the power is on
  • jmoebus Jul 10, 2008
    It is Audiovox 7" Widescreen Portable DVD Player, D-1708 and it won't show the picture even though the dvd player is on...When I press the play button, it won't work...
  • 4,234 Answers
Since you don't indicate what you mean by "won't work", let me provide a few possibilities:
1) You close the door and you can hear the DVD spin, but no reaction on the screen other than some type of "loading" message. This indicates that the optics are attempting to read the DVD but are having difficulties. The operation may ultimately be successful and the DVD may start, but the movie will be unwatchable because of freezes etc. In this case, try cleaning the lens using a cotton swab and alcohol. A dirty lens can cause this.
2) You close the lid and do not hear the DVD spin. In this case, the optics can not even determine that a disc is in the machine. Again attempt to clean the lens. If that fails to at least cause the disc to spin, the optics have failed and need to be replaced.
3) Try a music CD. If that plays OK, but a DVD does not, then the optics are defective and need to be replaced. DVDs require a more powerful laser and will typically fail sooner than CD levels.
Hope this helps,
Dan
Posted on Jul 10, 2008
    Genius:
  • 3,422 Answers
HI,
Did you try inserting different dvd's and see if it plays.If it doesn't the problem is with the lens.Please clean the disc lens with the lens cleaner.
  • Priya darshan Jul 10, 2008
    see if the player tries to read the disc. Load a disc and listen.
    Does
    the player make squealing noises or is it totally quiet? Squealing
    noises may indicate that the player is trying to synchronize with the
    disc but can't due to an obstruction on the lens or in the laser path
    inside the pickup or a defect in the pickup. This can also be caused by
    an intermittent signal problem due to a faulty ribbon cable.
    Totally
    silent means that the photo sensor is not getting any usable input from
    the laser at all, meaning that the pickup is "blind" for lack of a
    better word.
    This can be caused by an obstruction of the beam by
    foreign matter on the lens or inside the pickup all the way to a
    marginal or failed laser diode and/or photosensor array. This can also
    be caused by a bad ribbon cable with one or more severed traces.
    You
    could try to clean the optics. This is the most common malfunction as
    far as i know in all disc players. It would involve taking the cover
    off and finding a way to expose the lense, and then cleaning it with a
    very gentle brush. some players have a cover for the lense that swings
    to the side during playing, this greatly reduces the chance of dust
    accumulating, but its still worth the try.
    If you actually see dust on the lense, then its just that simple. clean, close, play.
    It may also be worth your while to check on the small shafting that
    guides the carriage of the laser pickup. Dirt, grome, dust and
    solidified lubricant can cause stoppage of the carriage and the laser
    eye then fails to read the next track. Please refer to the image i have attached.
  • Audiovox Master
  • 13,433 Answers
Sorry? can you clarify a little
reply / comment please.
  • Ekse Jul 10, 2008
    what is the brand and model of your device while you are at it..
My LG 4G LTE won't turn on even though it has been charging for hours.
do you have a universal travel charger? and use it to charge your battery for about 4 hours. or buy a new battery.If it is not ok, your phone is in short-circuit. go to service center
Apr 15, 2013 | LG Cell Phones
I have a sumvision cyclone voyager 7 It wouldn't turn off and after battery died it won't turn on even when plugged in Any suggestions? Thx Dave
Sounds like you may have a dodgy power button, you have a 1 year warranty I would call or e-mail sum vision, I have one of these systems and there not bad I've not had a power button problem though. Hope this helps!
Jan 02, 2013 | Audio Players & Recorders
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
How do I reset the computer after changing the battery in my 2004 mini cooper S? The car started three times. Now it won't start even though all of the other electrics work
Turn off ignition. Press and hold the trip reset button, then turn the ignition on (don't start the engine), within 5 sec the SIA status will be displayed. Release the reset button. Press and hold the trip reset button for 5 sec, "rst" will be displayed. Release and re-press trip reset button.
The new status should be displayed.
Oct 02, 2011 | 2004 Mini Cooper
Toshiba satellite may be stuck in Standby or hibernation mode. i TRIED HOLDING THE POWER BUTTON FOR 10 SECONDS AND RESTART, THAT DID NOT WORK. CANNOT GO INTO SAFE MODE. hELP
It sounds more like there was a charging issue and not enough juice left in the battery to start it up. Try removing the battery and then putting it in again. And then try starting it up. The adapter may be shot. Some laptops won't work if the battery is out or is shot even though the adapter is plugged in. Batteries generally need to be replaced every few years.
Also watch the lights on the front to see if they're coming on when you press the power button.
Jul 04, 2011 | Toshiba Satellite A135-S2386 Notebook
It will not turn on and the charger doesn't seem to work even though it is properly plugged in.
remove the battery and unplug the power adapter. press power button for 30 sec. then connect power adapter. press power button.
Mar 21, 2010 | Computers & Internet
MY CAMERA WON'T TURN ON SOMETIMES EVEN THOUGH I PRESS POWER VARIOUS TIMES
The power buttons on new camera's seem to have a delay in them. Try pressing the on button and keeping it pressed, gently, for about 2-3 seconds.
Mar 13, 2010 | Cameras
Camera won,t save picture even though there is flash & shutter sound
Sony Ericsson phones do not have a a specific "Save" button as such.When you click a photo , it automatically gets saved. They do have a specific "Delete" option though, be careful not to press that. Click a photo, n then exit the camera function.Check to see if the photo has been saved .
Jan 09, 2010 | Sony Ericsson K810i Blue Smartphone
Televison & Video Logo
82 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
