Question about Acer X193W LCD Monitor
Display moves when in games
Monitor is X193W; display on desktop is fine, but when I enter most games, Auto Config comes on and shifts the game display to the right and down so I'm missing the bottom and the right sides of the game screen. Auto Config doesn't move it back again, manual correction can't move it far enough.
  • 1 more comment
  • mrphammond Jul 13, 2008
    Thanks Blake, that fixed it on most games, much obliged!
  • deals911 Nov 21, 2008
    i browse fine, explorer internet browsing is fine, but games play on right side of my monitor, can't see all of game to play them. Doesn't happen when I play solitiare that is on the computer, just games I load.
  • Anonymous Dec 24, 2008
    Instead of shifting the game screen, it just goes fuzzy and zigzags, any other tips?
    Problem Solver:
  • 5 Answers
This is because your game is changing your video mode and timing. Check in the game's settings, see if there is a "use default video mode" option or if you can specify the 1440X900 mode manually.
Posted on Jul 13, 2008
When i start the game 'Total Overdose' my screen goes blank and input not supported message moves randomly but i can still hear the sounds of game intro
Skip the Game intro by pressing the enter key.Then move your mouse to the toppest position .Then press the down arrow.You will hear a sound.Press again and press enter[now you entered options menu]Press enter[now in settings]Press left arrow key to decrease resolution[4times]press enter .Press again to confirm.hope you problem is gone .I had the same problem and I used this way to solve that.
Sep 28, 2010 | Acer X193W LCD Monitor
Monitor's display is shifted up and right so that there is just black space to the left and all along the bottom whereby cutting off the display. cannot see bottom menu bar.
One of the buttons on the front of you monitor (bottom right hand corner of the bezel) is a menu button. Press that then using the the arrows up and down buttons go the the horizontal and vertical positioning option. Once chosen move the display as desired.
You could also press the Auto (config) button, that may do the same for you.
May 17, 2010 | Acer AL1912 19" LCD Monitor
Acer X193w-- input not supported..
This is likely a screen resolution issue.
That monitor has a native resolution of 1440x900 (I used to have one). If the game is feeding the monitor too high a resolution, the monitor can't display it and.....input not supported. So, if the game has a configuration option (without going into the game itself) set the resolution to 800x600 and try to play. If it works, bump up the resolution until it looks acceptable.
Hope this helps!
Aug 21, 2009 | Acer AL1916W 19" LCD Monitor
Can't change the resolution of ACER X193W. All attempts to change the resolution come up with "... not supported". What is the problem?
check in your computer graphic drivers are installed correctly.
If installed then when you power up the computer press F8 key then enter in enable vga mode.Set screen resolution to 1024*768 then apply and ok.
You can set screen resolution in control panel dispaly property.
Jul 14, 2009 | Acer X193W LCD Monitor
Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:
http://www.acerpanam.com/synapse/data/7117/documents/X193W%20(Qisda)%20user's%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
Jun 11, 2009 | Acer X193W LCD Monitor
Just bought an Acer AL2216WBD flat panel monitor. Have an old Dell computer; "Jewel Quest" game loaded. When I plugged in the new monitor, tried to play the game. Good sound but no picture. Only "input...
the resolution is incorrect for that new monitor , it does not support it, attach the old monitor reduce the display resolution and then hook in the new monitor, up the resolution until it fails again and do nothing it will reset to the last good display resolution and you can leave it there.
hope this helps
Mar 06, 2009 | Acer X193W LCD Monitor
Rapid shuddering of icons, pix on Acer X193W monitor (10 mo. old)
in very first you have to check the pc with another display monitor
if display problem still available check the graphic card and video driver. remove the driver and reboot. check display resolution and refresh rate
Apr 12, 2017 | Acer X193W LCD Monitor
Lg 24" monitor, loaded a game in new computer and now have of the monitor screen is lighter then the other half? any help
The game will contain a file config.xml or config.inf delete it and run the game your problem will resolve.
If you didn't find these files or the game does not contain the files then attached lg 24 monitor and start the game and go to option menu and in display sitting set the display at 800*600 or 1024*768 then save the setting.
Now you can pug the small monitor.
Hope this will solve your problme.
If this help you then mark as answer.
Thanks for using fix ya
Nov 29, 2008 | Computers & Internet
Black striped down left hand side of display
Hi Danny, you haven't been very clear I will assume you pushed the auto configure on the monitor,
I would go into the menu on the monitor and reset the size of the screen if it has a setting for that 1024x768 should fix the problem
let me know what you find as I have never worked with a hp W19 monitor, if nothing else set the monitor to defaults again in the menu and that may get you back to having normal screens.
L8r
Nov 13, 2008 | HP w19 19" LCD Monitor
Acer X193W LCD Monitor Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
