Question about Dell XPS 200 PC Desktop
Desktop Right Click Problem
Desktop Right Click is very slow from XP
    Sniper:
  • 51 Answers
This is generally an error from the registry, namely the context menu handlers (which is a shell extension handler that adds commands to context menus) If you can isolate when it started to occur and then maybe you can link it to a program you installed.
Are you having any having any other problems with your system emptying the bin, media apps??
I can suggest a progam that you can download that will allow you to see what extensions are in use and hopefully from this you will see if there are any left over commands from bad unistalls
Posted on Nov 27, 2008
Compaq presdio slow desktop windows xp
Follow these steps to fix computer freezes problem::
  • Remove unused programs
  • Install and run antispyware software
  • Free up wasted space with Disk Cleanup tool
  • Defragment your hard disk drive
  • Disconnect unused network connections:
Click Start, and then click My Computer.
On the Tools menu, click Disconnect Network Drive.
Select the network drives that you no longer need, and then click OK.
ALSO
Stop Unwanted startup programs:
Start > Run > write msconfig > Click on StartUp tab
Deselect the programs you want to stop
Delete Temporary Internet Files:
Click Start - Run, type in %temp% and then click OK.
Once that temp folder is open and you can view its contents, select and delete EVERYTHING that's inside it.
Repeat the steps with c:\windows\temp
After you're done with both temp folders, restart the computer.
Services:
Click Start, type services.msc in the Search box. Press ENTER. Right click and stop each service which is not necessary for you.
For an instant fix use Intel Software Partner Reginout. WebRepOverall ratingThis site has no rating(not enough votes)
Dec 13, 2012 | Compaq Presario 5000 PC Desktop
Tip
How to Connect a Windows 7 Computer to a Windows XP
Even though Windows XP and 7 are different versions of Windows, you can still connect a computer running Windows 7 to an XP computer using Remote Desktop Connection. Remote Desktop Connection is a utility in Windows that allows you to log in to a remote computer directly from your computer's desktop. However, before you can use the utility on your Windows 7 computer, you must enable it on the Windows XP computer. To connect to the Windows XP computer, you also need to know the XP computer's name.
Instructions
Enable Remote Desktop on the Windows XP Computer
  1. Click "Start" on the Windows XP computer, and then right-click "My Computer."
  2. Click "Properties" from the pop-up menu.
  3. Click the "Remote" tab, and then click the "Allow Users to Connect Remotely to This Computer" check box.
  4. Click "OK" to confirm the change when prompted on the pop-up window. Click "OK" on the open windows to close them.
Connect to the Windows XP Computer
  1. Click "Start" on the Windows 7 computer, and then type "Remote Desktop Connection" in the search box. Press "Enter."
  2. Click "Remote Desktop Connection" from the results list.
  3. Type the name of the XP computer in the "Computer" box, and then click "Connect" to connect to the XP computer.
References
  • ( Microsoft Support ) How to Use the Remote Desktop Feature of Windows XP Professional
  • !!!!CLICK HERE!!!!!
  • ( Microsoft Windows ) Connect to Another Computer Using Remote Desktop Connection
  • ( Microsoft Windows ) Remote Desktop Connection: Frequently Asked Questions
*please leave a rating if this information is helpful and beneficial to you.
Regards
MultilinkEnt.
on Jun 05, 2011 | Computers & Internet
How to change my desktop background ,i already try to click the desktop backround thats apear on monitor but nothing happen.
Try going to your start button > Control Panel > Change Desktop Background (it's on the left hand side... Windows 7) if not go to Display Properties and it should be there for XP.
Jul 14, 2011 | Acer Aspire One D255 Netbook
How to get the maximum screen size on hp30?
Is this in Windows 7 or Windows XP?
In XP: Right click on the Desktop. Hit properties. Click the advanced tab. Drag the resolution slider all the way to the right.
In Windows 7: Right click on the Desktop, click screen resolution. Follow the on-screen instructions.
Mar 14, 2011 | HP 530 Notebook PC
Ie 7 is very slow in response, XPsp3, initialy takes longer time resolving the Home page that is intranet page.
Right click IE icon on desktop and select properties. In general tab, click on the "Use blank" button and press ok button to close the "Internet Properties" window. Try this and your ie may launch little faster.
May 23, 2010 | Microsoft Windows XP Professional for PC
Wireless computers work fine, wired desktop extremely slow
On your old desktop, go to Control Panel > Internet Options > Connections > LAN Settings make sure no check on boxes there. Click OK and Apply. Click on General tab, click on Delete File (delete all offline content), Clear History and Delete Cookies. Click Apply and OK.
Jun 29, 2009 | Linksys Wireless-G WRT54G Router
Slow and quits and returns to desktop
is your using xp click on start then click on run then type msconfig then go to startup tab then disable all then click apply then the computer will asked you to restart your computer then after it restart it will show you a messagepopup then check the box then ok
if your using vista click on start then type on start search msconfig then go to start up tab click on disable all then click ok after that the computer will asked you to restart then restart ok. hope it helped
May 03, 2009 | HP Compaq dc7100 PC Desktop
Desktop ( Emachines 210 ) Very slow ? Ran via win xp proffesional
Try going to the control panel>performance and maintenance>disk cleanup. After running cleanup run the defrag. You can also cleanup your internet browser by deleting cookies, temp internet files, & browsing history. See if this helps speed up the system. Hope this helps & please rate this solution fixya. Thanks.
Feb 04, 2009 | E-Machines eMachines Desktop PC
Slow
what operating system are you using?
Apr 01, 2008 | Microsoft Windows XP Professional With...
Desktop icons
your problem is so simple just listen see below
1.go to desktop
2. right click there
3.open arrange icon by
4.then in second last their is lock desktop icon
5. click their your prob is solved
if go to desktop right click their and click properties
then click desktop
then click customise desktop in web their is lock desktop icon put tick out from their your prob is solved enjoy
Nov 15, 2007 | Microsoft Windows XP Home Edition
Dell XPS 200 PC Desktop Logo
57 people viewed this question
Alun Cox
