Question about Vacuums
I have a 6 gallon shop wet or dry vac. The dust and dirt comes out around the base of the motor fin, not around the tank top. Now what? Oh I lost the filter around the drum that holds the ball, so I wrapped a rag around it and made it secure. Respectively: TOM
Generic problem for all Vacuums
I have a 6 gallon
Posted by tsfroggy on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The bag is not going to do the job as well as the filter around the drum that hold the ball. The filter that goes under the motor does a lot of the filtering or you would have to do some type of cage filter then a foam filter and then a paper bag, I f you have a cartridge filter then the paper bag can go over the cartridge filter , B4 you do anything – id you have some type of compressor – use it to blow out the dust and dirt out of the motor, then buy a cartridge filter and then a paper bad with a rubber band to hold it on. This will do the best filtering . Check with your local vacuum cleaner dealer and bring in the top of your shop vac so that they can fix a proper cartridge / paper bag filter – or the cage frame with a foam filter with a paper bag. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Customer Service 570-326-0502 Phone #
Customer Service 570-326-7185 Fax #
Shop-Vac Corporation
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 10, 2008
I have Ridgid wet/dry shop vac, I was vacuuming
Did you have a paper/cardboard filter attached to the top part of the unit? Sounds like you didn't have a filter or the silicate material got past it and into the motor and windings. Bad news if this is the case. Try taking the top part off, turn it on to see if it runs without the bottom tank section. Double check to see if your vac has a fuze. If it won't go on you'll need to dismantle the upper unit and clean it all out. Hand turn the motor and see if it easily turns or is sluggish. My wife used my wet/dry vac without the filter and wrecked it with sheetrock dust into the motor. I dismantled the top, cleaned it twice and it's still no good. By the way, generally you have to take the paper filter out if you are vacuuming wet up. If you leave the paper filter on and vacuum wet up, the paper filter will get wet, shred and get pulled into the upper motor unit. A wet/dry vac isn't really made to pump water (by the gallons) out of places, so don't expect that. Okay yes you can often hook up an outlet hose to the drain port at the back of the tank and vacuum quantities of water, but it's not really made to do this.
Aug 28, 2014 | Vacuums
What is 700a shop vac motor size
Craftsman 17765 canister vacuum cleaner is known for its assortment of power tools especially when it comes to cleaning jobs. It is designed to give you an easier, more effective cleaning. This vacuum cleaner delivers a high capacity reservoir, power and the versatility to swap easily between tasks. Craftsman wet/dry vaccums soaks even drosp of water on the floor with one of their 16 gallon wet/dry vacuum. It is also equipped with utility nozzle, extension wands, and dust bag that makes the cleaning process easier. The extension wands can clean the hard to reach areas like cupboards, corners, and bends. It has a large gallon tank that includes convenient drain port for easy emptying when the job is done.
Number of Tools:
Attachment Type:
Details and Capabilities
Cord Length:
Tank / Bag Capacity:
12 Gallons
Hose Reach:
Cleaning Areas:
5 HP
110 - 120 V AC
Power Consumption:
1210 Watts
Jul 09, 2014 | Craftsman 17765 Canister Wet/Dry Vacuum
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
Mar 23, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Jul 16, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuums Logo
138 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
