What is the smallest mag stripe you can have - Computers & Internet
  • harryhaslam Jul 10, 2008
    Thanks for that, not the reader the actual strip on the card . does it have to be a cetain lenth for it to work.
  • 19,396 Answers
SMALLEST MAGS ON 2014 DODGE RAM 1500 HEMI???
nothing smaller than the original wheels will fit as the mag will jam on the brake calliper.
Talk to a tyre /wheel shop for what can be done.
Mar 08, 2015 | Dodge Ram 1500 Cars & Trucks
Ingenico 3070
If the ingenico is communicating with the pos system and just not reading cards, the mag stripe reader might need to be cleaned. try to clean it with a mag stripe cleaning card ( plastic/cotton card with cleaning solution ), swipe that through a couple times and run a test transaction. **folded paper towel and some rubbing alcohol works too if you don't have a card** I've cleaned alot of them that way working for a major drug store chain.
Oct 04, 2013 | Computers & Internet
How i can down load the drivers
Hi There,
The drivers are available here;
http://www.magicardonline.net
Just enter your printer's serial number in the QuickSearch box.
Jun 11, 2011 | Magicard Tempo ID Card Printer with Mag...
Driver for tempo id card printer vista 32 bits
Hi There,
The latest drivers can be downloaded here;
Dec 21, 2010 | Magicard Tempo ID Card Printer with Mag...
I have a 1987 rm 125 h need help on the wiring out of the magneto to the cdi box i dont have a plug on the mags wires the colors are black with a red stripe, green ,red , and re with white stripe the cdi...
Hmm, something has been changed at some stage.
All wires should be of same colour combo's.
Best guess is three wires from cdi go directly to magneto, whilst the fourth is for the coil. However your configuration suggest a different cdi unit is being used, the site below has a diagram of your bikes standard electrics, unfortunately not color coded.
Normally, it cannot be wired incorrectly as male/female and color wires determine correct connections. Find out the origins of the parts and seek the application for the color of each wire, ie: color wire for primary source, pulse coil, earth, etc. Transfer this info to the colors from your magneto, Goodluck and cheers.
http://www.cmsnl.com/suzuki-rm125-1987-h_model14053/partslist/FIG-22.html
Jul 30, 2010 | 2003 Suzuki RM 125
I recently changed from Preface to ID Works for printing my cards. At the same time I installed the Datacard printer driver ver 4.0 from CD. I have a SP 35 with and optional mag stripe kit installed. Now I...
Most likely your Mag-stripe info is missing from the card project in IDworks.
If you imported your projects from preface, its likly the box to include mag-stripe config was not transfer d.
enter idworks designer and click VIEW then field connections, there should be some info tied you mag-stripe field 1,2, or 3 of not there is the problem.
Next check printer plug ins in IDworks admin to make sure the mag-stripe plugin is installed. Also i would check Datacard.com Download section make sure you have newest and correct driver for your OS
if none of this works, uninstall everything (exporting projects) and reinstall.
Mag-strpe encoders can become defective, the encoder may need to be replaced.
Jan 02, 2010 | Datacard SP35 Printer
How do i program a mag card??
A mag card is simply a card with a magnetic stripe that holds data ... like a credit card or a hotel key, etc. The information on the data is actually just composed of a series of vertical lines. (If you actually had a thin enough magnetic razor blade, you could, crudely, create magnetic data onto a magnetic stripe).
In reality, all you need is a card writer. These are somewhat similar to a cd/dvd burner. You would get a series of blank cards, and you would need the track information and such that would go onto the card. The software that accompanies the write will allow you to input the correct fields, such as name, expiration date, card number, and track 1 & 2 data into the proper fields. Once those are put in, you simply put in a blank card, and "burn" it as you would a cd. The process takes maybe 30 seconds. When I last worked in the industry on that side of things a little over three years ago, a card writer was anywhere from $200 to $450 USD.
Sep 20, 2009 | Computers & Internet
KeyCard Types
There are several popular type of keycards in use and include the mechanical holecard, bar code, magnetic stripe, smart card (embedded with a read/write electronic microchip), and RFID proximity cards. The keycard is used by presenting it to a card reader; swiping or inserting of mag stripe cards, or in the case of RFID cards, merely being brought into close proximity to a sensor.
Aug 27, 2008 | DG Gold / Brass 98 Biometric Keyless...
Printing problem
No mag encoder means you're trying to send encoding data to the printer but the printer isn't configured with an encoder. A mag encoder writes data to the magnetic stripe you see on the back of some cards, like credit cards. Most likely, the printer doesn't have an encoder installed, but if it does, it may be turned off in the printer settings.
If you're sure that it does have an encoder, you can check/change the setting by going into the menu on the printer. Go to Menu -> Setup Printer -> Change Parameter -> Encoder Settings -> Mag. It will say none or installed. Note that this can be changed to one or the other whether or not the encoder is physically installed or not. This only turns it on if the encoder is there.
Hope this helps.
Jun 13, 2008 | Fargo DTC510 Card Printer
Computers & Internet Logo
David Payne
David Payne
