Question about Toshiba Satellite M45-S265 Notebook
Hdd password toshiba model ps610c-029zdp when i boot the main screen ask's me for a HDD password, I never make it to Windows toshıba setellite psm42u-016006 hdd pasword ı need
Hi, i need a recovering cd because i lost my.
i like to make sure that i dont lose all y progran when i instead the cd on the computer, how do u do that and do u sale one for last top?
Posted on Jul 10, 2008
When i turn my d257 acer aspire one on it goes to blue screen asking for a password, or it either goes to a screen that says no boot disk
No Boot disk found - usually indicates the HDD is not located.
so you need to validate the HDD is inserted properly, and locked into the HDD slot. securely,
Blue Screen asking for password, could mean several things,
basically you need with both errors, take to a good Repair Tech and have this looked into... PASSWORD can be either for BIOs or HDD,
or the system went into LOCKED MODE and password is needed to UNLOCK it.
Mar 03, 2015 | Acer Aspire One D257 Netbook
Unlock hdd/ssd password on toshiba satellite
Step 1Turn on your laptop. Press the "F2" key when the first loading screen appears. This will load the BIOS. You'll only have a second or two to press this key before Windows begins to boot. If you're not fast enough and the Windows screen comes up, simply restart and try again.
Step 2Use the right-arrow key to highlight the "Security" tab. This is the third tab from the right.
Step 3Press the down-arrow to enter the Security Settings menu. Scroll down to "User Password," listed beneath the "HDD/SSD Password Select." This will open a pop-up window with three text fields.
Step 4Type your current password into the "Current Password" field. Press "Enter." Type your new password into the "New Password" field and press "Enter." Type the same password again into the "Confirm New Password" field and press "Enter." The "Password" window will close.
Step 5Press the "F10" key to save your new settings and exit the BIOS. Your laptop will now boot normally.
TipHDD password can be changed as many times as necessary. However, once you enable password protection, you can never delete it.
Mar 24, 2012 | Toshiba Computers & Internet
Hi, I have a Toshiba Satellite L350D laptop which when booted up asks for a HDD password (which I do not remember setting at any point). As I understand it, the password is stored on the eeprom on the...
HDD passwords are designed to be 100% secure and there is nothing available to reset or remove the HDD password whether the password failure is caused by human error or HDD defect.
Users must ensure they have regular backups.Unfortunately,a new HDD will be required and is not covered by the standard warranty.
Mar 14, 2011 | Toshiba Computers & Internet
Please enter HDD1/SSD1 User password
If you get prompted for the HDD password when turning on the computer, and you do not know it you will need to call Toshiba support. Circumventing an HDD password is not an easy task.
Also there where Toshiba laptops, model 6100, that when the user was suddenly prompted for the HDD password Toshiba replaced the HDD under warranty.
Feb 28, 2011 | Toshiba Satellite L455S5980 Notebook
My PC with 865PE Neo2-FIS2R doesn't boot on SATA HDD... It actually runs windows server 2000. but after an unexpected power shutdown... the pc always boot on Managed PC Boot... upon checking on the Boot...
Hi Good day!! well i think your board didn't detect your HDD for some reason:
1. unexpected shutdown
2. cable not properly connect in HDD to motherboard
3. HDD have been damage because of improper shutdown.
here are the step to detect your HDD
1.pull out your cable from the HDD and then re-insert it make sure it its inserted properly.
2.go to CMOS and then in the "MAIN menu" check the primary master, primary slave, etc. in the primary master your HDD should be detect there. if not enter your primary master for auto detecting.
if nothing happens and still not detected you must replace the cable of your HDD.
Pls. Reply to help you more
Regards
JR
Oct 07, 2010 | MSI 865PE Neo2-FIS2R (MS-6728-030)...
How to recover the HDD password?
1800 series is an older Tosh laptop..and unfortunately there isnt an easy way to reset it. Since I have a Tosh laptop also, I was more than just casually interested in your dilemma..what I found is that you have to get whats called a loopback adapter and attach to the parellel port and start it up. The loopback is altered so that certain pins are shorted across(not as bad as it sounds) so that the BIOS resets. Try this website if you feel up to the task.
http://www.laptoprepair101.com/laptop/2006/02/10/remove-clear-toshiba-laptop-bios/
www.aa1consulting.com
Jul 26, 2009 | Toshiba Satellite A135-S2386 Notebook...
Bios Password problem solved but now HDD password awry
Just google "lost password" and you will find several utilities that will fix this. Simply burn the utility to a CD (they're typically in ISO format), and boot off the CD, follow the directions with that specific program. I've had very good success with that.
Jul 13, 2009 | Toshiba Satellite A135-S2276 Notebook
Cant boot
If you are sure no one has tampered with it and entered a HDD password and it is not prompting for a password then it is most likely a HDD failure. It is possible the BIOS will still recognize the HDD. Try disconnecting and reconnecting the HDD if you can access it there should be screws on the bottom marked with a cylinder symbol.
Jan 24, 2009 | Toshiba Satellite A205-S4617 Notebook
Cant boot
In your bios you should be able to change your settings for the hdd. Make sure everything in bios matches your hdd & then save changes & reboot. Hopefully that will allow you to enter windows.
Jan 24, 2009 | Computers & Internet
Hdd password
What is HDD Password? All hard disk drives have the possibility to set a hardware password, thus making the drive completely inaccessible unless a correct password is provided during the BIOS POST test. When you set a password on your notebook, the drive becomes locked as well. XBox gaming consoles and some desktop computers can also lock hard disk drives. This is usually called "HDD password" or "ATA password".
If you forget the original HDD password, there is no way of restoring it by generic system tools. HDD Unlock Wizard incorporates proprietary unlocking algorithms which allow to remove an unknown HDD password and make hard drive usable again.
I have a software enable to reset the password security on your harddriver but you need to pay my professional charge. If sound interested please email diazphi@gmail.com.
Please rate me solved if you like my solution.
Best regards,
Philip
Oct 30, 2007 | Toshiba Satellite Pro 6000 and 6100 14.1...
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
173 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
