MAGNAVOX TV MODEL MPTV68A (B) The TV loses picture after switch on. After several minutes, the time varies. If the TV is switched off for a while then swtched back on the TV will operate OK again for several minutes before losing picture.
  • yakamo Jul 10, 2008
    MAGNAVOX TV MODEL MPTV 68A (B)
    SEEMS THE VOLTAGE THAT FEEDS ONE OF THE PICTURE TUBE HEATER CIRCUITS DISAPPEARS AFTER SEVERAL MINUTES WHICH CAUSES LOSS OF PICTURE.
    PERHAPS SOME ADVICE ON WHERE I CAN AQUIRE A CIRCUIT DIAGRAM WOULD BE BETTER. DO YOU KNOW WHERE I CAN GET ONE ??
    ONLY PICTURE, AUDIO IS OK.
  • 796 Answers
You should be checking the thermal fuse..
may be that is faulty inside
Posted on Jul 10, 2008
  • 4,234 Answers
Based upon your description, the mosty likely cause is a poor solder connection in the high voltage section not the heater circuit. If you can solder, you should be able to resolve this yourself. Carefully remove the main board that contains the flyback trnasformer (part with large red wire coming out of the top) and check the solder connections in that area. Resolder any that appear to be grainy or have rings. That may resolve the problem. If not, we must start looking for components that are somewhat sensitive to heat in that area. There are protection circuits that will shutdown the set if problems are detected in order to prevent further damage.
One other question: I am assuming that the entire set shuts down, is that correct? or does the sound continue?
Thanks,
Dan
  • ABRsvcs Jul 10, 2008
    Thanks for the update. WIth the sound still working, the set is NOT in protective shutdown. As I stated above, teh most likely scenerio is that there is a bad connection in the high voltage section. Also check the connections at the vertical IC. This will be a small flat IC attached to a heatsink that will be marked LA7837 or something similar. The loss of vertical signal can mimic HV loss as well.
    Keep us posted.
    Dan
  • 2,071 Answers
Switch on and then switch off , is bad regulation of the incoming voltage could cause it could be a cold or brittle joint,a blown fuse, fusible link or other component.it could be one of several boards.Unfortunately,the level of sophistication on these TVs make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.
Find a repair man to avoid high voltage shock,.
  • 689 Answers
TV has internal overheating problem
  • ExpressFiX
    ExpressFiX Jul 10, 2008
    one of semiconductor is overheating so circuit cuts down the power.
  • ExpressFiX
    If you have experience on repairing circuits you might diagnose it, After opening the back cover there will be power circuit area check if hot areas, Also possible leakage of capacitors
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
Power indicator blinks; but no picture.
Likely to be the STK convergence chips causing a protection circuit to cut in and switch the TV off when turned on. Do you hear clicking when you switch on?
Kelvin
May 28, 2009 | Toshiba 57H81 57" Rear Projection...
Philips 60" rear projection needs warm up time
Sounds like your regulator ic is about to go, not an expensive repair but you have a good thought about buying a new set. If your fluid has never been changed I bet it's due also. Give the choice serious thought.
Feb 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
When sound & picture finally comes on the picture is pink and in the middle of the screen
This is a common problem with this model. The site www.magnavoxhelp.com has a chip kit to fix the no audio/video and video shrinking problem.
Sep 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
NO PICTURE HAS SOUND
I had the same problem. Check www.magnavoxhelp.com for instructions on how to fix it.
Jun 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
Have sound, lose picture. D52W23
sounds like a solder issue. try resoldering the Ics that are attached to heat sinks on the Board that has the flyback also resolder the flyback pin connections
Jun 18, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
60 inch philips magnavox
When you first turn on the tv, It goes from small picture to full screen and several corors around screen for a few minutes,I guess until it warms up? Could you please help? Thanks!
Mar 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
No sound-power switch on T.V. flashing 9 times
May be a bad optoIC. Goto www.magnavoxhelp.com to see if they have a repair kit for your model.
Oct 05, 2006 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
