Question about Microsoft Windows 98 for PC
Usb 2 gb usb flash drive exe. for windows 98
    Sergeant:
  • 213 Answers
Wat ur question
Posted on Jul 10, 2008
Need driver
Hi. Acually sir your usb flash drive is a plug and play device. Just plug it in on your computer and it should automatically be detected by your computer if you're using Windows XP, Vista or Windows 7. If you're pertaining to the Windows 98 driver you can download the driver on this link http://www.kingston.com/support/USBFLASHDRIVES/downloads/default.asp?s=DTI_HS , just click the DTI.EXE then it will let you download the driver for your usb. Goodluck!
Jun 19, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to my flash format
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format flash
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Feb 06, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Programme format Generic kingston 2 go
2. Format
Jan 03, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to get a driverfor pny 8 gb flas drive for
Then you will have to use a diskette or a CD, download the driver on some other computer, unpack and copy it to the diskette or burn on a CD-R.
Go to this link to download the drivers and for further reading on Windows 98 USB storage issues.
Dec 29, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I don't have driver of pen drive in windows 98
Let's check your Windows 98 Version first :)
  • Right click on My Computer and select Properties
  • On the System Properties page that opens up click on the General tab, if it is not already on that page.
  • Under the System heading, look for the version number (see right)
    • Version 4.10.1998 is the original version of Windows 98 (98FE)
    • Version 4.10.2222 is Windows 98 Second Edition (98SE)
  • Click the link below for the download and installation instructions for your version of Windows 98
Fo Windows 98 FE:
  1. Download and install the Windows 98 Service Pack (35.5Mb)
  2. Download to your desktop the driver file from the Download section below
  3. Remove ALL drivers for USB flash drives in Device Manager (Optional)
  4. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option) (Optional)
  5. Remove ALL unknown devices from Device Manager
  6. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  7. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
The drivers can be downloaded from the following link:
Windows 98 FE Generic USB Mass Storage Device Drivers v3.20
For Windows 98SE:
  1. Download the exe file to the desktop
  2. Remove ALL drivers for USB flash drives in Device Manager
  3. Remove ALL drivers for any USB 2.0 controllers (many have an uninstall option)
  4. Remove ALL unknown devices from Device Manager
  5. Run the exe file you downloaded, and follow the instructions, rebooting after installation
  6. When the computer boots up again, it may detect new USB 2.0 controllers, in which case you may need to reboot again
Windows 98 SE Generic USB Mass Storage Device Drivers v3.3
For detail explanation, please visit http://www.technical-assistance.co.uk.
It's help for me :)
Thanks
AkulahPathub
Mar 13, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Kingston 256 usb pendrive to run in windows 98
i suggest you upgrade your windows to windows xp pro sp2
windows 98 is not plug and play or you may try this http://downloads.drivershq.com/DriverDetective/DriverFiles/DriverDetective.exe
Feb 29, 2008 | Kingston flash memory card - 256 MB -...
Pen Drive Driver
You must install a "Driver" for it to work under Win98, go to the manufacturers web site and download the driver and install.
Feb 07, 2008 | SanDisk 8GB microSDHC Memory Card with...
Microsoft Windows 98 for PC Logo
16 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
