Periodically my HP PAVILION a465c WILL BEGIN TO "RACE" MUCH AS A CAR WOULD IF YOU STEPPED ON THE GAS PEDEL IN A CAR IN NUTRAL. WHEN THIS HAPPENS, WHAT EVER PROGRAM BEING USED FREEZES MOMENTARILY. WHEN THE RACING STOPS (15 SECONDS OR SO..) PROGRAM RESUMES.
Check your processor when this happens. If you see it is steadily at 53% usage and above check your processes (control alt delete). It could one of them is malfunctioning or in a loop. In my case it was a process called agent.exe. It was a macrovision update service named ISUSPM. I opened msconfig and disabled it. My PC is running like new. It was also causing my processor to overheat.
Posted on Aug 31, 2008
Nissan Cefiro A33 vs Toyota corolla 121 G vvti
OK, first you need to know the specs of both cars to have a guided guess. It is simple, find he the Horsepower (hp) for both, and the wiegh in pounds (Lb). Then for each car Divide the weight by the horsepower Lb/Hp and this will giive you how many pounds every horsepower has to carry. Compare results for both cars and the one with less pounds for each horsepower will have better chances of wining. Remember this is just a guided guess, since it works for cars in ideal perfect condition. There are other things which can change the results. One can be the hability of the driver to drive and to react in the start line.
You can help yourself by having your car loose weigh. For example, go to the race with a minimal amount of gas. Gas is heavy. Race alone in your car. Good Luck!! Be careful.
Nov 13, 2013 | Nissan Cefiro Cars & Trucks
2007 toyota camry- battery drained and check engine light on, no pressure in the gas pedel also
disconnect the battery again wait ten mins then hook it back up this should reset the computer ....as far as the gas pedal check under your car to see if your leaking any where
Feb 11, 2013 | 2007 Toyota Camry
Stepped on gas on my 2004 mercedes c240 and no acceleration then engine light came on, whats going on ?
If the sensor in the pedal value sensor fails the system,switches over to the second one .The throttle will be limited to 60%. A electronic throttle acuator will be the solution
Mar 28, 2012 | Mercedes-Benz C240 Cars & Trucks
Hoe to I get my hp 12c calculator to show the begin/end format? It did, now when o hit "g" "7" beg or "g" "*' end, can not get to display? Thank you !
Begin mode is obtained by pressing [g][7] and it should then show BEGIN in the bottom line of the display. End mode is obtained by pressing [g][8]. End mode does not not show an indicator in the display because it is the default mode, so if BEGIN isn't showing, then the calulator is in End mode.
Mar 18, 2011 | HP 12c Calculator
I have a 1997 nissan sentra with 1.6 litter engine. It has 171000 miles. The other day I run my car very low on fuel and went around a sharp curve (345 degrees) when I came out of the curve the car acted...
most likely a bad fuel pump, do you hear it hum when the key is on? fuel pump has to pump 180 pounds of pressure to operatethe motor, some pumps do come on but don't pump enough pressure for car to run.if ou have spark but no run, it's a fuel issue. you wre right o replace the inline filter, that's where i would've started.i suggest you replace that fuel pump. if you disconnect the fuel line at filter@ turn the key on, the gas should shoot out about 20 feet. hop this helps!!
Oct 03, 2010 | Nissan Sentra Cars & Trucks
Car seemed to go into nutral on own
Next time this happens without stopping or pushing gas shift tranny into N and then back into D and see what happens. The battery light came on because of low RPMs, no biggy.
Jan 20, 2010 | 2006 Toyota Matrix
Car will turn off when the gas pedel is released
gee where to start....fuel filter, O2 sensor,map or maf sensor, egr valve, get a fuel pressure tester and check psi at fuel rail. (35 to 45 psi. key on - engine off).
Nov 04, 2009 | 1999 Ford Explorer
Hp pavilion a465c desktop which will not boot
Make sure the power supply switch on the back is set to 115v, its normally a red switch but could be black.
Once you do that see if you can turn on the computer and get video.
If not then with the computer turned off, take out the memory sticks and reseat them one at a time in each slot one at a time and try turning on the computer to see if you get video. If you still don't get video then try taking out the CPU and reseating it back into its socket properly. At the same time make sure there is no dust or dirt on the cpu or in the socket.
Try again and see if you get video. If you don't get any video this time then disconnect everything and only have power going to the motherboard. If you do this and you still don't have video then the motheboard is bad and would need to be replaced.
Aug 27, 2009 | HP Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
