Question about Indesit W 123 Front Load Washer
Fixing broken door lock of Indesit W123X washing Machine
Indesit W123x washing machine door lock broken while opeing it. How to open door to remove cloths and how to replace the broken door lock mechanisam
  • 2 more comments
  • Anonymous Mar 16, 2014
    The boot came off while washing clothes I shut down the machine unplug it replaced the boot and ring closed the door plug it back in shut the door no power to it
  • Anonymous Mar 17, 2014
    I recently bought a viscount washing machine model EZ1000W & i cant not open the door a& the manual is locked inside
  • Anonymous Mar 21, 2014
    the door is not opened and locked while the clothes in machine
  • Anonymous Mar 31, 2014
    unable to open door lock simble showing
    President:
  • 1,462 Answers
No easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Posted on Jul 10, 2008
SOURCE:
Hi I have broken the door handle off my indesit wd10 washing machine and there are wet clothes inside how do i open the door and fix it
i saw same problem in another brand and it was easy it just open the small door of drain filer then open the filter slowly the water will out into sure small pan under this place you putted then we pull asmall plastic ring hang to ...... open the lock door then enjoy smell .. try this maybe it help .... i try to catch any infomation to you for this m/c but i did not found... thank you
Jun 10, 2009 | Washing Machines
Door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Door locked
sounds like your interlock has failed you can buy from any appliance spares outlet or online regards jason
Jun 08, 2008 | Indesit W 123 Front Load Washer
Help needed indesit washing machine
well it would help to know brand/model#
Oct 03, 2007 | Washing Machines
Door can't be opened
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure First disconnect the machine power cable from the wall socket. You should remove machine's top cover and then you will have an access to the door lock unit.
Sep 20, 2007 | Creda W120VW Front Load Washer
How can i open the door on my washing machine it wont open
Remove machine's upper cover and you will have an access to the door lock unit. Don't forget to disconnect the power cable first! Good luck!
Aug 01, 2007 | Indesit W 123 Front Load Washer
Door jammed
take the top off the machine,put your hand down to the reigon of the door lock and by using a small screw driver the catch on the door can be forced open without doing any damage.
Jul 24, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
1,087 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
