Question about Microsoft Windows XP Professional for PC
Want to burn .nrg Windows XP bootable image file in a blank cd.How i do this ?
Please tell me the answer step by step by nero 7.0 version software.
You can use CDBurnerXP (free) and convert NRG to ISO then burn the ISO using the same program
http://www.cdburnerxp.se/.
Posted on Jul 24, 2008
    New Friend:
I do this
Posted on Jul 18, 2013
Http://www.trafficpowerseo.wordpress.com
Posted on Nov 05, 2009
  • Microsoft Master
  • 19,396 Answers
You need to buy and install Nero, as Nero is not a free software.
Another option is downloading Izarc from
IZArc - DownloadIzark will allow you to unpack the files and burn using a different program.
Posted on Jul 10, 2008
  • Ginko
    Ginko Jul 10, 2008
    Install nero trial, it will work for some time. After installing nero just double click on the NRG file, nero will open automatically, press next several times and start burning.
    Here is the download
    Nero 8 - Trial
How to create a bootable Windows XP SP1 CD
Using nero .
Step 1
Create 3 folders - C:\WINXPSP1, C:\SP1106 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP1
Step 3
You will have to download the SP1 Update, which is 133MB.
Rename the Service Pack file to XP-SP1.EXE
Extract the Service Pack from the Run Dialog using the command:
C:\XP-SP1.EXE -U -X:C:\SP1106
Step 4
Open Start/Run... and type the command:
C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP1 contains: Windows XP SP1
How to Create a Windows XP SP1 CD Bootable
Step 1
Download xpboot.zip
Code:
Code:
http://thro.port5.com/xpboot.zip
( no download manager !! )
Extract xpboot.zip file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.
Select File > New... from the menu.
1.) Select CD-ROM (Boot)
2.) Select Image file from Source of boot image data
3.) Set Kind of emulation: to No Emulation
4.) Set Load segment of sectors (hex!): to 07C0
5.) Set Number of loaded sectors: to 4
6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:
Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab
Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)
Set Format to Mode 1
Set Character Set to ISO 9660
Check all Relax ISO Restrictions
Step 5
Click Label Tab
Select ISO9660 from the drop down box.
Enter the Volume Label as WB2PFRE_EN
Enter the System Identifier as WB2PFRE_EN
Enter the Volume Set as WB2PFRE_EN
Enter the Publisher as MICROSOFT CORPORATION
Enter the Data Preparer as MICROSOFT CORPORATION
Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN
* For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab
Check Write
Check Finalize CD (No further writing possible!)
Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP1
Select everything in the folder and drag it to the ISO compilation panel.
Click the Write CD Dialog button.
Oct 11, 2010 | Microsoft Computers & Internet
Tip
Create a new bootable CD for your Slipstreamed Windows XP using NeroROM
After you have slipstreamed the latest service pack 3 and all hotfixesin order to use this to perform a new install you will need to eitherburn a new CD or use the ISO mounted to perform it using a VirtualMachine for testing purposes.
The easiest way is to use Nero Burning ROM to create a Bootable CD you will need to follow these instructions
  1. Obtain the Microsoft Corporation Bootable image file (IMG) extract and save it using ISOBuster from an ISO image of the original Windows CD
  2. Open NeroROM and select CD-ROM Bootable option then select the image file you extracted in 1.
  3. Make the window look like the screen dump below,ensure that you select No Emulation and change the Load Segment ofsectors to #07C0 and the No.of Loaded sectors to 4
  4. Then select New
  5. You will need to add all the files from the folder that you have just slipstreamed the SP3 + post hotfixes
  6. I suggest that you save the project as GRTMHOEM_EN forWindows XP Home and GRTMPROF_EN for the Professional Version so thatyou can use it later for the same folder
  7. Press Burn, I suggest low burn speed X4 when using the Nero ASPI or create an ISO using Nero and the burn it using Patin-Couffin Interface option on ImageBurn with my AWS that includes 80% of all readily available media.
SCREENDUMP FOR COMPARISON
Happy Burnday !!!
on Jan 06, 2010 | Ahead Software Nero 7 Essentials Suite...
Nrg- files , how to open?
you can only open that file and make the icon file visible to your desktop by downloading cd or iso burner through nero, demon or alcohol. because .nrg files is a image extension file generate through software applications cd and iso image burners.
Aug 07, 2010 | Toshiba Computers & Internet
How i open a .nrg file?
You need NERO or a burning program that supports NERO format
Bob
Aug 06, 2010 | Microsoft Windows Vista Home Premium with...
I want a software with NRG files to download
A .nrg file is a proprietary CD image file format used by Nero Burning ROM, a utility suite made by Nero AG, to create and burn ISO 9660 CD images.
Other than Nero Burning ROM, a variety of software titles can use these image files. For example, Power ISO, Alcohol 120%, or Daemon Tools can mount NRG files onto virtual drives for reading.
Dec 11, 2009 | Microsoft Windows XP Professional for PC
HOW TO OPEN NRG FILE
NRG extension is for Nero Image, You can open it with Nero. Once you install Nero on your computer the nrg extension will automatically get associated with it and when you double click on the nrg file it will open with NERO
Oct 03, 2009 | Sony Trance NRG (SLTN75) for PC
Unable to Boot
I think you burn into CD\DVD is incorrect. Recopy any Software is OK using ISO, but to find out that your burn that into proper ISO also, It will not work. To burn is again is extracted from ISO back to Bootable Windows Vista DVD.
Here is a a tip, use another program like Nero to burn into image, the file is .NRG or .ISO...
Or for easy tip, try COPY DISC for assurance that it will run again as is.
Sep 13, 2009 | Computers & Internet
I Wanted To Make a BOOT CD For Windows XP But The Problem is That I Have Windows Vista and i Dont Know What To Do So What Can i Do
How to make a bootable Windows Vista ISO DVD media
  1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
  2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
  3. Exit from the Install Windows screen.
  4. Download CDimage 2.52.
  5. Extract CDimage from CDimage.zip to the C:\ root directory.
  6. Open a command prompt shell, and run the following command: cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
    Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
  7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Visit here for illustrative guide on using CDImage GUI version to make the bootable DVD ISO.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK).
  1. Complete step 1 – 3 as above.
  2. In the command prompt window, run the following command: oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
    A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
  3. Burn the ISO image file by using last step above.
Visit the guide to create Vista bootable DVD using vLite.
Note: For 64-bit Windows Vista, download etfsboot.com and put it into “\Vista\boot” folder. Or users using WAIK (WinPE), the etfsboot.com can be found at %Programfiles%\Windows AIK\Tools\PETools\amd64\boot\ folder. So simply replace -bC:\Vista\boot\etfsboot.com with -bC:\Program Files\Windows AIK\Tools\PETools\amd64\boot\etfsboot.com when making 64-bit Vista DVD image.
Aug 02, 2009 | Computers & Internet
Windows media player let me burn cd but other software dosnt work
All you need to do is change the device it is going to burn the files to. Apparently it is currently set to burn an .nrg image file to your hard disk. If you click on the down arrow next to the Image Drive, you will see your DVD/CD drives listed there.
Jun 07, 2009 | Ahead Software AHEAD NERO 6.0 SUITE 3...
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Microsoft Windows XP Professional for PC Logo
4,609 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
