Question about Hoover Washing Machines
Power is on - fuse in plug okay plug point working but nothing working on washing machine - hoover six 1200
    President:
  • 1,462 Answers
Probably the door interlock. easy part to fit and not too pricey
Posted on Jul 10, 2008
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
Jan 19, 2016 | Bosch Washing Machines
Hoover nextra 1200
HAVE YOU CHECK FOR THE CONTINUITY OF EACH PARTS ON PSUPPLY AREA?
LET ME KNOW
PS CHECK ALSO THE RESISTOR/CAPACITOR
Sep 11, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
My washer dryer is filling up at the start of a
Check motor brushes wear out after 4years..5.....
Apr 13, 2010 | Washing Machines
Hoover vision hd washing machine was working then tripped power. checked plug socket, plug fuse all working. there is power to machine but no power showing on control panel. could it of blown a relay etc?
Could be faulty door interlock, as nothing will work until this activated..
On the other hand, could well be power module or display module that is faulty.
The only thing thing you can do at the moment is to remove the top cover, and see if there is anything obvious looking in at the top
Hope this helps.
Feb 01, 2010 | Washing Machines
Machine partially fills and then stops working.
THE RCD SWITCH is concealed on the inner side of the hindges of the door or on the top innerside of the door. it is a simple push switch which has a mechanism of push to on/off
this switch has got stuck in off position.
change this switch or spray a drop of rust removal oil. it will start functioning
Aug 27, 2009 | Whirlpool AWM8123 Front Load Washer
Hoover 1200 front loader washing machine is tripping mains ecb
you have a direct short circuit unplug the machine and remove the plug cable cover then: look for wires touching or, wires touching the metal of the machine the plug wires should only touch their respective screws if these are alright then take a multimeter set it for resistance (ohms) place one probe on a plug pin and the other probe on one of the other plug pins if you see continuity you have a short check all interior wires until you find a blackened burned wire etc. when you have high continuity you have fixed the problem
Apr 26, 2009 | Washing Machines
User guide for hoover performa eco 1200
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=10
go to that website to get an online manual for any hoover machine. the performa eco is a WB120.
Mar 26, 2009 | Washing Machines
Hoover 205 washing machine
The actuator arm for the out-of-balance safety switch had become misaligned from the safety switch. As such, it had tripped but could not be reset.
Jul 03, 2008 | Hoover Washing Machines
Manual
Click on Hoover (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Oct 05, 2007 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
153 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
