Question about Gateway FPD2275W LCD Monitor
No display i have pc with usb mouse and keyboard which ae not being detected and also i am not getting any display at all to see what fault there is. checked the cables, ram, and processor, everything seems to be working fine but i am still not getting any display. what more can i do?
  • pvishrut Jul 10, 2008
    the graphics is onboard so i can't really change vga card
  • Shaehype Jan 24, 2009
    I have a Gateway 17' monitor that looses power ..then as soon as it is plugged out for -20-30 seconds it regains power...then it displays a VGA message, How do i solve this?
    Sergeant:
  • 233 Answers
Replace the vga card
Posted on Jul 10, 2008
  • Darwish Al-helo
    Darwish Al-helo Jul 15, 2008
    so add other one on pci or agp port
Optiplex 780 computer USB and VGA problem
Hi Tigistunet
are there any bleeps on startup? try checking that the card in in securely, remove and replace should be sufficient, if no joy then I think that your graphics card is most likely at fault, this will stop the pc from booting and prevent the mouse and keyboard from being powered up. Unfortunately it could be almost anything but I would start with the graphics card. Hope this helps.
Feb 19, 2013 | Dell OptiPlex Computers & Internet
PC no longer detects mice
You said that you are using a USB mouse, when you tried another mouse on this PC was it also a USB mouse, or one of the more basic mice you plug into the tower? I suggest trying to use one of these mice so that you may have a working mouse, and then if that works use it to try to get at some of the input settings that could be in need of adjusting.
Hope this helps some.
Jan 07, 2013 | Dell Dimension 5150 (DIM515MIN) PC Desktop
When i start my pc i get the error "please enter
One or more of your USB devices connected to your PC are malfunctioned, remove any usb connection exept keyboard and mouse. Boot the PC , if the error still exists then reboot after removing your Mouse first and keyboard at second. Tell me what happens after these.
Sep 14, 2011 | ASUS P5KPL-AM SE Motherboard
The Gateway GT5404 can't detect the keyboard and mouse, i try to get in the bios but the option can't appear
Try using a PS/2 keyboard and mouse, not a USB. That usually does the trick, so you can get into the BIOS and change the settings to accept USB keyboards and mice.
Thank you, -Larson Custom PC Team
Apr 30, 2011 | Gateway GT5404 PC Desktop
I have a Dell PC and I unplugged the mouse and the keyboard temporarily to clean it. When I plugged them both back into the tower and turned on the computer, neither one worked. I tried to restart, shut...
To try to resolve the issue:
1.) Will a different keyboard and mouse work (PS2 is the name of these connections)
If they will, damage to the keyboard and mouse is likely)
2.) Will a usb mouse and keyboard work?
If they do, then the problem is with the controller on the mobo, unlikley but MAY have been casued by static.
If the USB keyboard and mouse do not work, you have some problems with the motherboard
Try switching off and unplugging the computer, remove the coin shaped BIOS battery and plug in the keyboard and mouse, wait 2 minutes or so and put the battery back, replug in and power on, see if the bios detects the keyboard and mouse (you will see the bios screen flash up a message). If the computer does nOT detect the keyboard and mouse it will (or should) flash a message on the screen saying "no PS2 keyboard or mouse detected".
If this fails to detect the mouse and keyboard and you get no message or beeps, then there may be damage to the connector ports.
If you can get a USB keyboard and mouse to work, use them, Effecting a repair to the motherboard will not be a viable option
Jan 25, 2011 | Dell Dimension XPS 400 PC Desktop
Batteries ran down in the optical mouse. I put in new batteries and now I can't get the mouse to work. it's frozen
Remove the battery off and keep aside from within the mouse. Now disconnect the USB - optical detector to the PC. Shut down the PC . Replace battery once again and power the PC, then connect the USB to see if the mouse is detected.
If not remove off installed software of the optical device and reinsert once again so that it gets detected.
Nov 25, 2010 | Innovations kb985w RF Wireless Keyboard
Usb device not detected mouse
try a new mouse or try the current mosue with another PC that will give u a fare idea of what's wrong...if the mosue is ok then it should work in another PC else, u nned to get a a new mouse...
another option is to buy a new PS2 mouse that can go into the external keyboard/mouse point behind the laptop, that way if there is an issue with ur USB port it will be known...
Dec 17, 2009 | Warrior 797146022002
Gateway one wirless keyboard has just resently quit working the only bottons that work are mute and valume my mouse stil works i am using the onscreen keyboard now tried new batteries what now
there is a bottom that rests the key board and the mouse and detect them from the usb blug try to press this bottom and detect the keyboard and the mouse
Sep 30, 2009 | Gateway ONE GZ7108 All-in-One Desktop PC
No keyboard or mouse response
Hi, Check in your Bios if Usb keyboard and Mouse Support is enabled, otherwise you can use a Ps2 Keyboard just to get to the desktop, then you should be able to install your keyboard and mouse, yor pc should automatically detect the devices
May 17, 2009 | Dell Computer Refurbished OPTIPLEX SX270...
When I restart my computer It does not detect the keyboard/mouse
Sometimes, USB Keyboard and USB Mouse give such problems. Try using conventional (PS/2) Keyboard and Mouse.
Mar 29, 2009 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
