Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi power board pcb post
I just read your comments and checked the outstanding pics of the power board and believe i have the same problem...you could help me a great deal if you could pinpoint the exact location of the power board. to replace C9A51-52-37-38 etc.
i have the caps and a general understanding of the removal process, but, again the pcb location??
thank you for any assistance
  • shinsatob Sep 29, 2008
    I need to know where to get the replacement parts to fix this problem, and I need to know what they look like. I just called a repair guy and they said it would cost me about 400 to fix it. Plus 80 for them to tell me the problem.
    E-Mail me at
    shinsatob@rush-enterprises.com
  • 927 Answers
Good day, steve sc;
The DM board is normanlly on the left side TV looking from the back. It has a shield around it, remove. The caps are big and black, they look the replacements(only ones on board). Here's what says about this issue:
If the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). (LED does not stop blinking after plug in) On the DM
Good Luck, big IRISH. ps hope this helpful!
PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
It is not an easy job, it will take some time but since you have it apart there is another problem that will accure so might as well do this too:
Tile or block pattern with no video or OSD. Check D8F00 and D8F01 part # 264P828010, also check C8F26 and C8F29 part # 141P148000 (1 uFD, 25 V) on the FMT PCB (part # 930B924002).
All the parts have location numbers like C8F29 that will tell you what and where these parts are.
Good luck, big IRISH.
Posted on Jul 19, 2008
Mitsubishi CK3560R
Good Day;
Try these first. This TV is an oldie 1988?
POWER SUPPLY STARTS BUT WONT RUN. CHECK FOR SHORTED D909 OFF T905 PIN 17 AND/OR SHORTED IC401. (PCB-MAIN) D909 PT.# 264P521020 IC401 PT.# 272P174010 *** ( TO PREVENT REPEAT FAILURE , REMOVE T905 FROM PCB AND RE-SOLDER LEGS OF TRANSFORMER AND THEN REINSTALL) 2. POWER SUPPLY WONT RUN. CHECK FOR OPEN FOIL AT PIN 2 OF T905. (PCB-MAIN) 3. POWER SUPPLY WONT RUN. CHECK FOR OPEN R903 (220KOHM) AT PIN 3 OF IC901. (PCB-MAIN). ALSO CHECK THE VERTICAL OUT IC, LOOK IN POWER SUPPLY CIRCUIT FOR LEAKY CAPS. YOU CAN TELL BY BLACKNESS ON THE BOARDS ON THE NEGATIVE SIDE OF THE CAPS.
Sep 20, 2008 | Mitsubishi WS-55807 TV
I need help
Good Day, RONALDSADAT;
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 16 V).
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Aug 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My tv
Good Day, fidel59;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Jul 15, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Need a repair solution e-mailed
Good Day, jnjetsn;
Jul 13, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking green light
Good Day, pipe filtr;
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
MITSU 65513 BLINKING GREEN LIGHT WONT POWER UP
Good Day, xbossux;
Jul 09, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 green blinking light
Good Day, nixonam;
Jul 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513
Good Day, nixonam;
Blinkink light
Good Day, jcarnell;
Jul 05, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Where do I get a PWB-signal 930B923002?
Try alldatadiy.com or acrobatfiles.com/mitsubishi or splodeman.com/Mitsubishi
Sep 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
497 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
