Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Bosch front loader washing machine water pump?
Bosch front loader washing machine water pump failure
  • 2 more comments
  • Anonymous Aug 29, 2008
    no water!!!
    checked the hose filters, water pressure and other suggestions in the manuel
    doesnt work
    its BRAND NEW!!!
  • tcharolais Oct 08, 2008
    I bought mine today and nobody can tell me what is wrong. I checked the hoses, the water pressure and everything like Customer Service said and still nothing. I have no clue. Please help!!
  • Anonymous Mar 20, 2014
    The door on my front loader is very loose, but I cannot get to the screw as it is behind the point where the door pivots. TO close the door I have to lift it and slam it
  • Anonymous Mar 28, 2014
    What does E3 mean
    Problem Solver:
  • 4 Answers
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
How do i drain the water from my bosch nexxt front loading washing machine to remove the pump filter
I believe if you can get to it, put the hose end lower than your tub and it should drain. My front loader quit pumping and it was two quarters stuck in the pump.
Jan 02, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch WFF2001. Works OK in wash cycle but leaks heavily (from drum seal?) on rinse. Not from door seal. Any ideas?
This video will show you how to change a door seal on this Bosch WFF2001 front loader washing machine
May 02, 2011 | Washing Machines
Water leaks in all programs
Bosch WET 2820 Front Load Washer / Dryer water
Leaking.
This video will show you how to change a door seal on this Bosch front loader washing machine .
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 27, 2011 | Bosch WET 2820 Front Load Washer / Dryer
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Sep 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My bosch wfk2401 front loader is stuck on spin
Hi
There is a door bottom right of the system which has a screw out (by hand) plug.
Remove this and ensure there are no foreign objects such as coins, bobby pins etc stuck.
I have found this to be a problem with the Bosch systems and cost me $150 the first time.
Ensure you have some towels as when you open the plug, water will escape
Mark
Mar 04, 2009 | Bosch WFK 2401
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
961 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
