Question about HP Color LaserJet 4550n Printer
Hard drive or memory
My printer appears to have stopped working. It just ignors me!
I believe it has a 64mb memory, and I have bought a 128mb sd ram replacement, which I have not yet fitted.
My concern is that the problem might be with the hard drive and I have been advised that I can hook this up to my compuer for testing if I can remove it from the printer. So I have been trying to find the manuel which on line so that I can discuver how to do that, but I have not been sucessful.
Can you either tell me how to remove the hard drive or how I can easily get the manual? I bought the printer in 2001. If you think the hard drive is not likely to be the problem, please let me know.
Thank you.
Joe.
    President:
  • HP Master
  • 1,314 Answers
Try reseating the memory that is there.
I have the service manual available. Please rate as fixya and leave me your email address and I will send it to you right away. Thanks.
Posted on Jul 10, 2008
Types of sdram
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Mar 03, 2011 | Computers & Internet
What are the hardware requirements for foxpro?
  • Processor: Pentium-class processor
  • OS: Windows 2000 with SP3 or later, Windows XP or later, Microsoft Windows Server 2003 or later
  • Memory: 64MB of RAM min., 128MB recommended
  • Hard Disk: 165 MB of available hard-disk space for typical installation; 20 MB of additional hard-disk space for Microsoft Visual FoxPro 9.0 Prerequisites
  • Drive: CD ROM or DVD-ROM drive
  • Display: 165 MB of available hard-disk space for typical installation; 20 MB of additional hard-disk space for Microsoft Visual FoxPro 9.0 Prerequisites
  • Mouse: Microsoft Mouse or compatible pointing device
from: http://msdn.microsoft.com/en-us/vfoxpro/bb190292
Mar 02, 2011 | Microsoft Visual FoxPro 9.0 Professional...
What is meant by a memory failure Replace dimm 0
There is a memory stick in a socket on the formatter board in the right side of the machine. If you pull the right rear cover to the rear it will come off revealing a metal cover you open by the tab. Once open it shows the formatter board. Inside is a laptop sized memory stick,or DIMM. With power off you spread the tabs to release it then pull the memory out, same as in a laptop. You likely have 96mb RAM - most come with a 64mb memory on the formatter (non removable) and a 32mb option. On the P3005N and P3005DN the memory is required to make the embedded (builtin) network card function, otherwise you can run it fine without the bad DIMM if you use USB. If you want to replace you need a 200 pin DDR2 DIMM in either 32mb, 64mb, 128mb or 256mb value. Last I bought was on ebay for $20 for a 128mb brand new. HP wants like $220 for the same.
May 19, 2010 | HP LaserJet P3005n Printer
Can Inksaver 2 run on Windows 7 64 bit?
InkSaver 2.0 System Requirements:
  • An inkjet printer (InkSaver 2.0 works with all inkjet printer brands including HP®, EPSON®, Canon®, Lexmark® and many more*).
  • Any PC running Windows® Vista, XP Home, XP Professional, or 2000.
  • At least 20MB of available hard drive space.
  • Minimum of 64MB RAM (128MB RAM recommended).
  • InkSaver supports parallel, USB and TCP/IP printing and multiple printers.
Sorry but it does not say anything about 64bit
Dec 20, 2009 | Computers & Internet
Beeping on start up
Your motherboard has 64Mb built-in RAM and the video card needs some video RAM and has grabbed 8Mb of RAM which leaves the system with 56Mb of RAM. When you insert a 64Mb RAM module you have a total of 128Mb of which the video has grabbed 8Mb which leaves the system with 120Mb.
You can't change stop the video card from grabbing 8Mb of RAM, the RAM is essential for the video to work.
You can upgrade the RAM by removing the 64Mb RAM module and insert a 128Mb or 256Mb RAM module. You may even be able to insert a 512Mb RAM module if the motherboard will accept it, you need to check the specification of your laptop to see the maximum amount of RAM the laptop can handle.
May 21, 2009 | Compaq Evo Notebook N150 Notebook
IBM netvista PIII type 6579 MNU doesn't boot
Sound like the memory is not compatable, try booting with no memory installed and see if the hard drive appears, if so it's a memory problem.
Apr 05, 2009 | Computers & Internet
What kind of SC memory card do I need to get for a Toshiba PDR-3330 digital still camera?
The manual says, "SD Memory Cards having the following storage capacity can be used on your camera (Toshiba PDR-3330):
8MB, 16MB, 32MB, 64MB, 128MB, and 256MB"
Aug 22, 2008 | Toshiba PDR-3330 Digital Camera
PNY 2GB memory card
I have the same camera and bought a 4GB PNY SD card and it wouldn't work, so I read the manual :) The manual says, "SD Memory Cards having the following storage capacity can be used on your camera (Toshiba PDR-3330):
Hope this helps! -Kim
Jul 15, 2008 | Toshiba PDR-3330 Digital Camera
Memory card question
I think its just a warning message but it shouldn't stop you from recording to tape.
If you can pick one up and install it in the camera, that will get rid of it.
It should take SD cards. They can be anywhere from 64mb to 2 gig in size. You should use the high speed cards as well such as a San Disk Ulra II. Standard cards may cause quality issues.
May 24, 2008 | Canon ZR800 Mini DV Digital Camcorder
HP Color LaserJet 4550n Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
