Question about RCA Lyra RD2850 20 GB MP3 Player
HDD Fatal Access Error
My refurbished unit had been working fine, ableit with a few quirks, but nothing I couldn't live with since I got a great deal on it. However, now I'm having an issue that I can't live with. While transferring a file to the unit, it gave me a message "hdd fatal access error, the unit will restart." The unit stopped and did not restart. Every time I tried to start the unit, I could feel the guts churning, but I kept getting the same error with the unit stopping. I then tried plugging the unit into the PC via the USB cable, and my PC won't detect it as an external drive any longer. My PC has an old operating system (Win98), so I tried using my laptop which is running WinXP and still no use. Is there any way to salvage this mp3 player, or am I just SOL?
Thanks for any help you can offer.
  • HeatherJn Jul 16, 2008
    I've managed to get the unit to play again. While off, the unit would not reset when holding down the off button for 10 seconds. I tried a different approach by turning the unit on and, before it got to the HDD Access Error, holding down the off button for 10 seconds to reset. This worked, and I got to my music. However, my PC still won't recognize the unit as a separate hard drive.
HulkSmashNow
  • 5 Answers
SOURCE: File Sytem Corrupted!
The dreaded "File System Corrupted" error is one that comes time and time again. Did you drop the player or hit it by accident? If so, then the pin connecting the battery to the micro hard drive has probably been disconnected. You can removed the back of the player with a screwdriver, but you risk tearing off the S/N sticker. If you decided to do it anyway, remove the back of the player and then simply fit the multi-pin connector back into the hard drive. Replace the back and screw it in, and then turn it on to see if it works. I did this with my old RD2762A, and it worked like a charm. Hope this helps!
Posted on Aug 30, 2007
  • 75 Answers
SOURCE: error??
Try using this it worked for my m4002a. It's the firmware update software.
http://download.rcaaudiovideo.com/downloads/autoupdater.exe
After downloading that just follow the instructions that pop-up with the program.
Mine wouldn't do anything before i tried this and afterwards it's been working without a problem.
Posted on Jan 02, 2008
  • 3 Answers
SOURCE: RCA Opal M4002A Won't let me access playlist without shutting down
You need to re-image your firmware--it sounds like something is corrupted there. I have seen this behavior on other mp3 devices in the past; sometimes it requires special techniques to reset the device. Let's hope this isn't the case with your Opal--RCA was rude enough not to provide a handy reset procedure.
If you are daring you can try to replace the firmware files directly on your Opal using your son's files. You need to enable viewing of hidden files to do this: Tools-->Folder Options...-->View-->Show Hidden Files and Folders. Also uncheck "Hide protected operating system files (Recommended)" and say "Yes" to the dialog that pops up. You can change these back later. For MacOS X, open Terminal, then type "defaults write com.apple.finder AppleShowAllFiles TRUE", push Enter, Option-click (and hold) the Finder icon, then choose Relaunch.
Now, simply copy your Opal's files over to a local directory on your hard drive (this is a backup so you can't make things worse), and then copy your son's Opal files onto your Opal. The files should be as follows:
autorun.inf
playqueue.dat
pmp_usb.ini
RAMLIST.DAT
SETSTOR.DAT
STDBDATA.DAT
STDBDATA.IDX
STDBSTR.DAT
STDBSTR.IDX
All of these files should be placed in the root of the drive--in the folder on the Opal that also shows folders like "Audible", "FMRecord", "Music", "Pictures", etc. After the transfer, stop and unplug your Opal. Try to turn it on and see what happens. If it looks OK, try to hook up to it with Windows Media Player. If you are still having trouble, use the firmware from the RCA website--even if it is the same version. Failing that, you may need to have the device serviced or replaced.
Good Luck!
Posted on Dec 04, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Need USB Driver for RCA TH1101A MP3 Player Win98 2nd
RCA once had them, but no longer carries them. You would actually have more problems than you would imagine with Win 98 and mp3 players anyways - no music services will accept Windows 98 anymore. The Windows Media Player 10 software that you would need to transfer songs is not compatible. It would have been rough anyway.
-Tha Mp3 Doctor
Posted on Jan 09, 2009
  • 9 Answers
SOURCE: Using an RCA MP3 player, model M4304...After
http://www.rcaaudiovideo.com/product.aspx?product=420
follow the download link on the right hand side of the page and download the firmware and easyRip software upgrade
Posted on Dec 08, 2009
Magellan roadmate 1440 fatal error
Same has happened to my gps unit too. The best bet thing is to contact Magellan and they will advise you to send the unit in for replacement with a refurbished one. or get a new one. I am still waiting for mine and as of date, nothing yet. How is it that their updates caused the fatal error? Anyone??
Jun 23, 2014 | Magellan RoadMate 1440 Car GPS Receiver
When i Start the game.Then it comes an error.SAYS(Fatal error: Couldn't flip Directx message: Unknown error)
The problem with your game is that the DirectX component compatible with the game is not installed properly or there are some files missing in the DirectX directory.Try re-installing the DirectX.
Thank You
Dec 26, 2012 | Project IGI IM GOING IN
My d'link dsl 2640u keeps disconnecting. i try to access the router throw 192.168.1.1 but nothing shows every time i need to restart my PC then everything would be fine and i can ccess the router...
Does your PC work on other networks reliably? If so- it's likely the DLink failing. The firmware issue is just a symptom as well. I'd recommend either seeing if you could use your DSL provider's original modem (if this was a replacement) or if you have another router- if it doesn't drop at that point, it was definitely the router/modem. However, if it drops still, you may have a line issue- but I severely doubt this since the symptoms are pointing to the DLink.
Jun 08, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I just bought an IBM Thinkpad r31 for my kids, that may have a connection problem, or it may be with the HDD or controller. It comes on intermittently, and when it boots, may only stay on for a few minutes...
It's the HDD, its spin-up time (the time it takes the motor on the platters to reach normal operating rpms)  is too great so the system can't decide if it's a hard or soft problem so it freezes.
Nothing more you can do, replace it.
Jul 07, 2010 | IBM ThinkPad R31 2656 Notebook
The display is showing Service Call 132:Fatal
I solved this problem easily (Once I found it!)..open lid, locate where the top section bright metal lugs contact with copper leaf contacts at the front of the base unit and clean them with some fine emery paper or gently with small flat screwdriver... mine had a bit of toner dust and a tiny carbon deposit which was preventing the circuit being made. This showed the fatal error 132 and you may notice on start up that the normal rotation noises within the machine were silent too. Worked for me. Problem arose after Xmas break when machine had been stood for a few weeks. Good Luck! Bryan at Pinewood Studio Manchester.
Nov 17, 2009 | OKI C9600n Led Printer
Iomega HDD Fatal Error 05
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 05, 2009 | Iomega ScreenPlay
Enquiry abt HP pavilion laptop price
check the link below , for the currently shipping system at HP.
http://www.shopping.hp.com/webapp/shopping/series_can.do?storeName=computer_store&landing=notebooks&a1=Brand&v1=HP+Pavilion
You can get a great deal on holiday packages.
Shop by phone: 1 (866) 638-2088
If you are planning to buy a the DV6700, ie no longer shipped .. the refurbished price tag should be around 200$ not more than that .
Alternatively you can look at Dell , as they sell refurbished systems at great prices.
www.dell.com
Thanks
proton
Dec 09, 2008 | Computers & Internet
Red, green yellow, flash red
I had to pay the $149 for a refurbished system, lost all of my hdd data, and had to deal with Sony's HORRIBLE customer service for a few hours of my life I will never get back.  I recieved an identical 60 gig ps3 with only a 90 day warranty.  When I asked about PAYING for a longer warranty they said a longer warranty absolutely wasn't available.  Pretty bitter about the whole thing.  New Ps3 works fine, but now I shudder every time I turn it on, for it may be the last : (
Nov 04, 2008 | Sony Playstation 3 (PS3) Console
RCA Lyra RD2850 20 GB MP3 Player Logo
29 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
