Question about Tomtom Go Plus GPS Receiver
I cant turn on my GPS tom tom
Yesterday i just use my GPS is narmal
but today when i turn on
notthing come up
but when i put charger have some green light on it
but on screen is nothing come up
what can i do
    Problem Solver:
  • 5 Answers
Hi not good news,there was answer to this on another posting.
2 ICs blown-U24 and U25.
Common fault,cost over here in UK £50 to fix,not an easy.
Posted on Oct 16, 2008
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
I have a TOM TOM one XL GPS and it will not power
If you where having difficulty with the on/off button, it sounds like the microswitch under the plastic. Unless you can do micro soldering you can not fix this yourself. You should get a quote from tomtom.
May 29, 2010 | Tomtom ONE XL GPS
A while ago I put a larger sd card in to my unit,as i wanted to install the complete maps of the U.S.A, i PUT A uLTRA 2 GIG CARD IN, IT WORKED FINE, PUT MY GPS AWAY FOR A FEW MONTHS, YESTERDAy i put the...
Most likely you got a hot copy of the maps and it worked fine for a few minutes in the new unit. Check the course of the map because they know if they are purchased new or are being copied. Not saying you did anything wrong just saying the SD card can only be used for one unit. Contact the company and they will set you straight.
Apr 30, 2010 | Tomtom GO GPS Receiver
My tomtom will not turn on. I have had it plugged into the car charger for several hours. Help?
try a reset first, i will assume you cant do this, get a clip or pin switch off the unit and remove the sd card, then push the tool into the small reset hole underneath and hold for 15 seconds, then turn your unit back on and replace the sd card, it should then work if not it could be the battery has worn out as they are attached to the charger all the time when driving, hope this helps
Jan 02, 2010 | Tomtom ONE GPS Receiver
We have bought a tom tom 910 its about threeyears old it worked at first but now it wont work at allthe green light wont come on all the time to
Try doing a device update while connected to tomtom home, if that doesnt work backup your device onto your commputer and try reinstalling the software and maps ect onto your device.
Aug 02, 2009 | Tomtom GO 910 GPS Receiver
Tom Tom not working
hold the power on button down until it turns on, does this help, also being plugged into charger with green light coming on normally means that the unit is charged.
Jun 21, 2009 | Tomtom ONE GPS Receiver
Tom tom will not switch on
try charging the tom tom fully and then reset while it is charging. a tom tom will not reset unless the new battery is fully charged which may take some time if you only have a car charger.
please give me a fixya! rating if this helped.
Apr 04, 2009 | Tomtom ONE 3rd Edition GPS
Tom Tom One Doesn't Turn on
you should learn some elecricity and change some parts that broken, or buy new one, because it is out of waranty, or you can apply the problem to the ebay seller, start to think!!!
Feb 22, 2009 | Tomtom ONE GPS Receiver
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
Hi my tom tom go 700 dosnt turn on
I had the same issue. I used a paper clip to press the reset button on the bottom of the device.
I hope that works for you. Good Luck
Dec 12, 2007 | Tomtom GO 700 GPS Receiver
Tomtom Go Plus GPS Receiver Logo
81 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
