kb and mouse not work mean
1-the toice is damaed if no
2- ps2 soket is damaged if no
3- resistance in mother board is damaged and need to replaced if no
4- I/O ic is damaged in mother boared
OK! It could that the monitor is damage or it could also be that video card is damage!
* Be advice that some video are on board video which will means that you will need a new motherboard if that goes wrong. If it's one that just pci which means you jus put it in a slot on the mother board then you can replace that it could still be a mother board as well!
So need to check depending on what type of video you have!
This can be a faulty power supply or a damaged mother board. here's how you can confirm.
When pressing the power button, inspect the cooling fan that is located on the back of the power unit where the power cord plugs in. if the fan starts then stops immediately, this will confirm a damaged power supply.
Now, if the fan continues to operate but, the CPU doesn't start to power up and load the OS, thsi will confirm a mother board issue. replace the mother board in this case.
Hi, if this is lightning damage then unfortunately you are up for a new router and pray that your mother board has survived.
To check motherboard, open case use a torch and study the capacitors in side. these are round objects that stand out from the board in rows of up to 6. if any of them show signs of bulging out the top or bottom then your mother board is also most certainly damaged and will need replacing.
Regards mistyman
place of purchase and price
