Question about LG LDF8812 Stainless Steel Built-in Dishwasher
I have a LG LD1403W1, when you turn the power button on it sounds like it is shorting out. You can then oush the start button it commences to wash the dishes. After about 3 minutes the FE fault starts but continues to wash. There was a electrical burn smell when this problem first started. The dishwasher then stops.
SOURCE:
  • 105 Answers
SOURCE: indesit dishwasher
machine is flooded in base
means you have a leak in dishwasher
dismantle check feed pipe to top basked probable faulty feed pipe replace if so
Posted on Feb 24, 2008
  • 489 Answers
SOURCE: Model LD1403W1
Are you using a rinse aid like Jet Dry??  All dishwasher manufacturers now require that you use rinse aid for drying dishes at the end of the cycle.
Posted on Jun 08, 2008
Master_Tech
  • 770 Answers
SOURCE: LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
Not reached to the normal
water level in spite
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker
Posted on Aug 20, 2008
  • 423 Answers
SOURCE: What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Posted on Mar 30, 2009
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Wm2688HNM REPAIR, MACHINE WILL NOT STAY ON UNLESS I KEEP THE POWER ON BUTTON PRESSED, ONCE I RELEASE IT THE UNIT TURNS OFF. wHILE THE BUTTON IS PRESSED THE RED LIGHT IN THE MAIN pcb BOARD IS ON
Sounds like ur power on button may be shorted, u can check it with a multi meter, for continuity when pressing down it should show continuity. and none when released, To test it you can jumper the 2 wires together and see if it runs when plugged in? if not its ur push start button other wise I would think maybe the control board is bad
Dec 04, 2016 | LG Wm2688hnma Front Load Washer wm2688hnma
Dishwasher wont start
Most likley problem is the door is not closing properly or the door latch switch is faulty. This means the dishwasher controller is not getting the right signal before commencing the wash cycle.
Need to check the closure of the latch. If this is ok then replace the door switch.
View the door panel diagram, schematics and parts in this site
http://spares.bigwarehouse.com.au/index.php?cPath=24759_25855_26296&sort=2a&page=1
Apr 23, 2014 | LG Dishwashers
Lg wm2240cw won't turn on
Replace power button. Easy. Inexpensive. Check out appliancepartspros.com or repairclinic.com.
Dec 16, 2013 | LG Washing Machines
Simpson eziloader 5.5kg washing machine When i turn it on and select a program the machine clicks and the light flashes three times and then turns off the cycle (the cycle does not commence).
1.Turn off machine 2.unplug from power 3.leave unplugged for 5-10 mins 4.open door (if has water in drain via pump/lint filter (botton right flap). 5.empty contents(if wet turn drum by hand( may be unbalanced) close door) 6. turn on power 7. select colours 40 cycle 8. press start button 9.wait a moment ( chip reset ) 10.hopefully machine will fill with water and let complete cycle
Jan 11, 2011 | Washing Machines
Drumlight won't turn off then locks down the system.help
  1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
  2. Press the Power button, while in the above condition. Then buzzer will sound twice.
  3. Press the Start/Pause button 15 times.
  4. The unit powers off.
Oct 22, 2009 | LG WM2688H Front Load Washer
Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Model LD1403W1
Dec 29, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG LDF8812 Stainless Steel Built-in Dishwasher Logo
79 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
