Question about Whirlpool Dryers
Dryer does not dry - Whirlpool Dryers
thanks for the prompt reply it an electric whirlpool awz121.
Posted on Jul 10, 2008
  • 417 Answers
need to know if its gas or electric, easy way to tell is to look at the power cord going into the dryer, does it plug in next to the washer or does it have a thicker heavier plug near the floor? thicker plug means its electric, smaller cord means gas. Dryers are dangerous appliances. If you have any doubt what yoru doing stop and write here or call a pro. Be careful to shut the breaker off in the fuse box or shut the gas off outside the house before you do anything else. Most likely if its electric the element burnt and you need a new assembly, or if its gas has their been a disruption of gas service lately? How ******* is your laundry room? You should always leave the door open to your laundry room so the dryer can breathe. If you come to find that your laundry room may not have enough airflow, the thermocouple in a gas dryer will go if it cant breathe also. let us know
hope that helps
  • Jude Meredith
    Jude Meredith Jul 11, 2008
    hi,
    okay shut the breakers off , pull the plug and pull the back cover off, there will be a rectangular box with red wires coming out of the bottom, this is your element box, pull the wires off and remove the box and put it on something flat, you will have to use a circuit tester to test it or you can visually inspect it if you dont know how to do a continuity test with a tester. an open circuit means its blown, if you want to visually inspect it, you have to remove the element from the box theres a couple more screws on the box, you will visually see a break in the element, take it up to the sears parts store. Its about 20.00 for the element. If you fix it you just saved yourself a you know what worth of money, if it still doesent work, I dont recommend doing high voltage tests, call the man
    later
    J
It is taking far too long to dry, this has only recently started? what could be the problem?
Does it get hot? If it does, then the problem is reduced air flow, caused by a lint filter that hasn't been cleaned, masses of fluff in the exhaust pipe (usually on bends), or the external vent not opening properly. Birds can also nest in the vent pipe if the vent isn't protected or is broken.
If it doesn't get hot, you need a new element. Some dryers have two elements if the dryer has a high and low setting. just one element can fail.
Jan 20, 2016 | Zanussi TC7102W Electric Dryer
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
Jun 17, 2010 | LG DLG7188 Gas Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
Not enough heat
You may need to adjust the air flow on your dryer vent.
Problem:
Solution:
LG DRYER SERVICE MANUAL
LG PARTS
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
New dryer, not drying clothes, vents cleaned, old dryer worked ok
repl/ thermistor and coils,,, remember these machines have moisture sensors,,,,,,,
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
UN-ending Auto dry cycle
This is caused by the dryer vent being blocked and not allowing the moist air to be removed from the dryer. To confirm this. Dry a load of close in a timed dry setting. Set the time on a specific time and then start the dryer. Wait for about 5 min. See if the timer has moved. If it has then the problem is not the timer. It is the exhaust vent being plugged up somewhere. Moisture how the auto dry setting works. The dryer sences moisture and runs longer to dry your clothes. With the dryer exhaust vent blocked, wet moist air is comming back into the dryer and fooling the sensor into believing the close are not dry and runs for a very long time. It is not uncommon for this problem to cause a dryer to never shut off. Your dryer exhaust vent is plugged up with lint somewhere.
Nov 10, 2008 | Dryers
Dryers Logo
110 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
