Question about Technics SL-1210 Turntable
Won't stop hi my technic's haven't been used for 1 1/2 years ive just started using them and when i press stop they don't stop dead it takes a while also if im speeding up a record the whole thing keeps getting faster and faster till i turn the power off can you help
  • 515 Answers
This is a common issue with the drive in these units. Unfortunately, there is no easy fix. You will need to take it to a qualified service center for repair.
- Davis
DIGITAL ANALOG THERAPY
www.REPAIRNYC.com
Posted on Jul 12, 2008
Hi i have technics Compact 5 Disc Cd Changer SL-EH790
Carousel-type changers such as yours are prone to eventual failure.
Mar 23, 2014 | Technics Audio Players & Recorders
Aftermarket stereo won t power on
you blew the fuse
check the fuses to radio, can be 2 or more.
1 in fuse box.
2 in radio, (some have 1 , and others have 2 or 3 more in side radio)
anything is possible with aftermarket, radios, 10,000 models, vast years. Ive repaired many. (ET)
the radio has a red wire, usually for power,
most radios have 3 power wires,
1 for rad ( this one dead) use a volt meter here.12v key on.
1 for dial
2 for memory
Dec 06, 2013 | 1995 Honda Accord
MY 3 YEAR OLD PACKARD BELL LAPTOP TAKES UPTO 3 MINUTES TO SHUT DOWN
You could try removing items from startup. Start > Run > type MSConfig > Startup. Uncheck items you don't want to load. This will make your PC faster. This can also be done with CC Cleaner if you haven't done so already.
Aug 27, 2012 | Packard Bell Computers & Internet
Sony laptop dead problem
Could be many things. Let start with a couple of easy ones.1) Unplug charger from computer and outlet, take battery out press power for at least 30 sec. Plug every thing back power on. 2) charger bad won't turn on or charge battery, try diferent charger if don' know how to use a voltmeter. 3) power jack loose or broken. 4) last and worst mother board circuits transitors etc... btw processor, video card or input devices fried. Buy new board from ebay. Don,t fix it. Not worth it. This is Only if laptop gives completely sign of not turning at all. No lights, no hardrive or no working or fan. No signal of life. If couple of lights do turn on it can be the ram or video card, play with ram a bit. Good luck.
Dec 09, 2011 | Computers & Internet
When I press the foot pedal it just whines until I manually move the hand wheel and it starts sewing. It will sew but each time I stop I have to "help" it get started by turning the hand wheel. ...
Have you checked the tension setting and also, see if the belt spins free when you press on the foot petal. If the belt seems tight and isn't slipping it's something else. Belts aren't hard to change. Just difficult because you kinda/sorta don't take no for an answer and with slight force, get the old one out and squeeze the new one in while turning the wheel by hand with a little pressure. Seems wrong but that's how they change them in the shop!
Aug 31, 2011 | Vacuums
Car Won't Start - Engine No Completely Start. It is starts but stops immediately.
You haven't provided much information on Year or Engine model.
This condition could be caused by many things, ranging from fuel, air leak to sensor issues.
If your vehicle is 1996 (or newer), your vehicle's onboard diagnostic (OBD2) computer will have stored the fault codes relating to this condition.
Have an approved service agent check for codes (this only takes 15mins) which will quickly identify the suspected circuit/component.
The above process will save you unecessary expense.
Cheers,
Aug 28, 2011 | Mazda MPV Cars & Trucks
The lap top don't recognize my battery
If you haven't replaced the battery in recent years, it is entirely possible that the battery is fully dead and won't be detected by the operating system. You can try taking the battery out and putting it back in. Updating the BIOS on the laptop with this could also be worth a shot as it can correct battery detection issues.
Aug 23, 2011 | Compaq Presario X1000 Notebook
Hot water tank - Bock model 51E Was working perfectly until a couple hours ago and then stopped. I have a red light indicator on and I've pressed the red button reset and the motor started up for...
Call service technician.
Call Boch Phone: 608/257-2225
http://www.bockwaterheaters.com/technical/engineering.html
I don't see a service manual posted on internet.
Without a service manual showing ohm-readings for testing different parts, you are left guessing which part is problem.
Most water heater manuals today recommend yearly service to catch up on most causes for failure including air in fuel line, dirty or corroded burner parts, defective sensor, loose connection, etc.
Jul 30, 2011 | RTO Bock Water Heaters 51E 50 gal 152,000...
Hi! I have a Nikon Coolpix. I haven't used it in a while. I charged it over night but it won't turn on.
Your batery is dead they don't like long period of staying discharging (If you 100% shure that your Nikon is working) The time of charge dosen't matter.
Jun 02, 2011 | Nikon Coolpix S210 Digital Camera
Wrench support
impact wrenches are often misused by those who don’t know about their special needs. First of all, it is very important to be careful when tightening a nut or bolt with an impact wrench! Cross threading can occur very easily; a novice may also over-torque a bolt or a nut if they don’t know when to stop. To prevent such problems, always be sure to hand-tighten every nut or bolt before using the impact wrench; if you try to start the nut or bolt with the impact wrench, you won’t be able to feel if the threads are crossed. If the impact wrench is not torque controlled – meaning it will stop when the nut or bolt is tightened to a certain torque – you will need to go slowly, and periodically check the torque value of the nut or bolt to make sure you haven’t tightened it too far.
Aug 27, 2008 | Campbell Hausfeld 1/2" Impact Wrench
Technics SL-1210 Turntable Logo
80 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
