Question about Refrigerators
Freezer not defrosting - Refrigerators
    Sergeant:
    Champion:
  • 330 Answers
Check the blower
Posted on Jul 10, 2008
Defrost instructions
Manual Defrost model freezers must be defrosted manually. For best operation the freezer should be defrosted when the frost accumulation becomes 1/4 to 1/2 inch thick.Defrosting Instructions for Upright Freezers: Turn temperature control to OFF and unplug freezer.
Manual Defrosting Instructions for Upright Freezers
products.geappliances.com/appliance/gea-support-search-content?contentId=19298..you can also go to this link that should help you out... Defrost instructions Google Search
Oct 23, 2017 | Refrigerators
What could the problem be; my refrigerator not cold but the freezer is freezing?
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail with illustrations how to dx and fix: Refrigerator Defrost Parts
Jul 31, 2014 | Emerson Cr500 Refrigerators & Freezers
Refrigerator and freezer get cold but freezer does not freeze whirlpool 1997 model et22dkxfn00
Can you remove the rear panel in the back of your freezer and tell me what the frost pattern looks like? When a refrigerator loses Freon the frost pattern looks like this photo HERE If the rear wall of your freezer looks like this you still are having a defrost problem photo HERE
Here is what that will look like behind the rear panel of the freezer should the defrost heater and defrost thermostat need replaced HERE
You mentioned that you have already replaced the defrost timer so we should not be concerned about that. The defrost heater=> 2315530 Defrost Heater
The defrost thermostat=> 4387503 Defrost Thermostat
I will be here should you have questions or comments, Thanks Sea Breeze
Mar 04, 2013 | Whirlpool Refrigerators
Freezer is working refrigerator is not.
The freezer is not defrosting. Look at the back wall of the freezer section and see if it is frosted. Locate the defrost timer and advance it till it clicks once. This should advance the freezer to the defrost cycle. Check to see if the defrost heater is on. If the defrost heater is glowing behind the freezer rear panel the you know you have to replace the defrost timer. If the heater is not glowing then you have to check if the defrost heater or defrost timer is in default.
Dec 27, 2009 | Amana ABB1927DE Bottom Freezer...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Freezer suddenly is creating mounds of freezer "fluff"
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Sea Breeze
Aug 20, 2009 | KitchenAid KSRS25ILSS Side by Side...
Freezer frosts up and food gets soft
Repair the defrost system, defrost timer,defrost thermostat and defrost heater.
Aug 18, 2009 | Refrigerators
Freezer not freezing
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer
If the freezer is in defrost then the freezer fan should be off. Only on the electronic will the freezer fan come on in defrost but the freezer door has to be held open for 3 min before the fan comes on
Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
391 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
