Question about Canon Office Equipment & Supplies
Canon i865 6x4 photo tray - knob wont turn to engage paper seems jammed. Thanks
Embarrisingly simple fix. The printer was pushed up close to our wall thus not allowing to the paper feeder sit back normally. Therefore the photo tray was not sitting correcly. Once placed in the proper position, it all worked fine.
Thanks for the response though.
Kind Regards.
Posted on Jul 11, 2008
Canon pixma mp495 rear tray rollers only pulls paper in on one side then it jams
When the paper does not feed straight, dirty or sticky rollers can cause it to jamb or crinkle, also failure to remove all traces of paper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these pieces of paper. The rollers may be dirty or sticky and causes the paper to not feed straight.
Try cleaning the rollers with methylated spirits.
Mar 30, 2013 | Canon PIXMA MP495 Wireless Photo...
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon ir2800 is hanging after 2\3 copies what to do ?
How is it hanging.... What is wrong with it? Is it jamming or coding out? If it jams make sure the paper tray's are set to the same direction and size of paper in the paper tray. The knob for paper size input get's moved by the "Knob Mover".... Good Luck
Feb 28, 2010 | Office Equipment & Supplies
Paper jam
Hi usually paper jam at paper input area a or transfor section(photo drum area or fuser unit area, so you may try:
1) take out paper tray and open the cover that you can change toner cartridge there (see manual) looking for any paper inside paper input area or around the cartridge, then take out jam paper.
2) open fuser unit at paper output area ckick a locker at somewhere (see maanual) looking for any paper jam
Dec 22, 2008 | Canon imageRUNNER 1310 Printer
Paper Jam With No Paper
sensor out of alignment...with a strong light look for a black plastic sensor
Jul 11, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
My Canon ir c2100 has a paper jam issue.
Have you tried to run copies from both paper trays? Will it jam in the same spot with both trays? If one works, but the other jams, it may be as simple as making sure the paper tray is set to the correct paper size? Is it set up in the paper tray as LTR, but the tray is saying LTR-R on the display. If so just change the paper size knob to the correct size. Also, if it stops in the same spot with all of the trays, look for something blocking it. Also, try to cheat the side door and make sure everthing is turning correctly.. Good Luck...
May 22, 2008 | Office Equipment & Supplies
I had a paper jam in my ip4200.
Make sure the paper ways are clear of bits of paper- a vacuum cleaner hose? Also look in on www.fixyourtownprinter.com
Jun 01, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
49 people viewed this question
old marine
old marine
Corne Viljoen
