Question about Toshiba Satellite M45-S331 Notebook
SYSTEM RESTORATION No hdd in this laptop. So how do I connect a 3 1/2 hdd just for testing purposes. I have a 2 1/2" hdd adapter and the 2 1/2 hdd frame that is inside the system. Also there is a little black connector that fits through the hdd frame then slides onto the mating 40 pin type connector which is embedded. So I'd like to know and see what is needed to connect a hdd temporarily so I can install the Restore CD and get to the reason why the restore cd has failed. Or were can I get a SCHEMATIC OR REPAIR MANUAL FOR THIS Satellite M45-S331 SYSTEM UNIT, MODEL PSM40U-01R001. Ineed to see if I am missing hdd connector parts.
  • mrudulph Jul 12, 2008
    could not find the link
    Thanks anyway
  • Toshiba Master
  • 4,924 Answers
If you do have a hdd in your laptop ..but when you run the recovery or the installation cd it said you do not have a hard disk on the machine ..It may not be a problem ,,but just a setting matter ..If the hard disk is on a sata bus..and it is seen in BIOS setting s..you may try to disable the AHCI funtion for it in BIOS ..and let it run on ide compatible ..The idea is that in ahci mode it will not be seen by any operation system unless it has the driver installed and the driver can be installed only on a working operation system or as a 3rd party during the installation process..By disabling the function in bios..you basically eliminate the need for the driver and will see teh hard disk right the way ..
If this is the case remember to save settings with F10 ..
To know immediately if it will work just go to bios..and look and see if the hard disk is seen there..(on hdd 0 ) if it is ..it means it will need to work ..so look around for the ahci and disable ..
Posted on Jan 04, 2012
The first thing you said was 'No hdd in this laptop'.
You need a hard drive, so the easy solution would be to get the right size drive for your laptop and go from there.
Posted on Jul 29, 2008
My msi is fx620dx eject key doesnt work.what shall i do?thanks
SEE SIR THIER COULD BE MANY REASONS FOR IT
1. FAULT WITH OPERATIONG SYSTEM
FOR THIS PURPOSE YOU CAN SYSTEM RESTORE YOUR PC ACCORDING TO THE DATE YOU ARE FACING PROBLEM
(SYSTEM RESTORE RESTORES YOUR SYSTEM SETTINGS TO PREVIOUS DATE WHEN IT WAS WORKING FINE)
STEPS
1. GO TO START
2.ALL PROGRAMS
3.ACCESSORIES
4.SYATEM TOOLS
5. SYSTEM RESTORE
6. RESTORE MY COMPUTER TO AN EARLIER TIME
7. SELECT THE DATE ACCORDING TO THE TROUBLE YOU ARE FACING FROM ()YOU WILL NOT BE ABLE TO SELECT ALL DATES THICKER LETTERS ONE CAN BE SELECTED AS THEY CONTAIN CHECK POINTS)
8. RESTORE
NOTE:
YOUR SYSTEM WILL BE RESTARTED AND SETTINGS WILL BE SHIFTED TO EARLIER TIME BUT BACK UP YOUR OS DRIVE THAT IS C,DESKTOP, MY DOCUMENTS E.T.C LOCATION FOR IMPORTANT THINGS BEFORE DING THIS SOME TIMES MIGHT BE RISY
AND IF STILL THE PROBLEM EXITS EITHER SEE BY FORMATING OR SIMPLY TEST WITH OTHER USB KEYBOARD IF ESC BUTTON WORKS ON USB KEY BOARD THEN
2. CHANGE THE KEY PAD
Apr 28, 2013 | Computers & Internet
I have a Toshiba Tecra A-6EZ6312 and I can't get it to load up. When it is starting up it goes to a screen that says Intel (R) Boot Agent GE v.1.2.30 Copyright (C) 1997-2005, Intel Corporation CLIENT...
You neglected to mention if it has booted up in the past but considering the age of your computer, I'm assuming that it has.
More than likely your hard drive (HDD) has failed and you'll need to replace it and reinstall XP. The only other option really would be that you've got bad connections or that the interface between the hard drive and the HDD has failed. That's unlikely though because you wouldn't get a message about no OS being installed, you'd get a message about not having a HDD installed because your computer can't see it. A computer can still see a HDD even if its failed providing that it can still receive power and communicate with the motherboard. Before you do anything, though, pull the HDD with the power off on the laptop (one or two screws at the most) and battery and power supply disconnected. Then, power up the computer without the HDD. The System BIOS should recognize that there is no HDD installed and yell at you for it. Power down the computer, disconnect the power supply and the battery again and reinstall the HDD. Then power up the computer. That may solve the problem. If not, keep reading because we're going to need to test it before we make any decisions.
To confirm that it is a dead hard drive, you'll need to test it on another computer, preferably a desktop as it will be the easiest to do and hopefully won't require you to spend any money other than on a SATA cable (unless you already have one) just to test it. I've looked up the technical specs on your laptop and it came standard with an 80 GB SATA 2.5" HDD. Assuming that your using the same hard drive that came with the laptop, and your desktop has a SATA interface and power as well, you'll first need to disconnect the hard drive from your laptop . Now, if your desktop doesn't support SATA or you're using a second laptop to perform the test, stop right here and advance to the second section that covers performing the test on non-SATA desktops and second laptops.
SATA Signal Cable: captainhawk1_5.jpg
SATA Power Cable:
captainhawk1_6.jpg Connecting to a Desktop Computer that supports SATA Interface For the Purpose of the HDD Test:
The easiest way to tell if the computer supports SATA interface HDD is by looking at the HDD currently installed on the desktop. I always use non-conductive (latex, neoprene) gloves when I work inside of a computer to prevent static discharges that can destroy your computer. You should too.
Turn off the desktop, and disconnect power. Open the case. If the connections for that HDD are SATA, the cables that are connected to it will look like the examples above. If they don't, your computer does not support SATA so you'll need to stop and go on to the next section.
Now, you'll need a SATA signal cable (if you don't already have an extra one). You can get a SATA signal cable at any electronics or computer retailer. It shouldn't cost you more than $5.00. Next connect one end of it to the laptop HDD and the other end to the connection on the motherboard that will most likely be right next to where the SATA signal cable for the primary HDD is already connected to.
You shouldn't need to purchase a SATA power cable (indicated in the second picture) or a SATA to Molex adapter cable because your power supply should have at least one or two extra SATA connectors attached to it. If by some chance it doesn't, you'll need to purchase a MOLEX to SATA adapter cable (see the image below) and connect it to one of the several Molex connectors attached to the power supply (labeled with a "P" and a number. Example: P7). Again, this adapter should be easily acquired at any electronics/computer retailer and should be no more than $5.00 Now, connect the SATA power cable (or adapted cable) to the laptop HDD. You're now ready to do the test. Keep the case open when performing the test to monitor the laptop HDD and because, well... it's a heck of a lot easier than constantly opening and closing the thing and considering you'll have an HDD in there that's not mounted to anything, it's the safer bet. Skip the next section on connecting using a desktop computer that does not support SATA and go directly to the section on performing the test.
MOLEX to SATA Power Adapter Cable (may have multiple SATA connectors as well): captainhawk1_7.jpg
Connecting to a Desktop COmputer that Does Not Support SATA Interface (Supports IDE) or Connecting to Another Laptop For the Purpose of the HDD Test:
If the desktop computer you are using to perform the laptop HDD test does not support the SATA Interface or if you are using another laptop computer to perform the test, you are going to have to connect the laptop to the computer via USB interface. To accomplish this you will need a 2.5" Hard Drive Enclosure. A hard drive enclosure converts an internal hard drive into an external hard drive. They cost between $5 and $25 and you'll get a better deal online. Following the directions for the enclosure, connect your laptop HDD to your test computer. You should be able to easily tell if the drive is spinning up and the LED's on the enclosure should be flashing just like they do on a computer when a HDD is being accessed.
Performing the Test:
This is the easiest part of the whole show. If you haven't done it already, reconnect the power cable to the test computer and power it on. Go to My Computer on the desktop of the test computer (Computer if running Vista or Win7), double-click on it and a window will open. Once you find the laptop drive, double click on it and start searching around and see what you've got. If you don't see the drive, we've confirmed that the HDD has failed. If you do see the drive but open it up and there's either nothing on it or you get error messages when you attempt to access the folders, the hard drive has failed as well. In either case, you will certainly need to replace the HDD as I suggested in the beginning however, your data may still be retrievable. You'll need to get it to a local computer repair shop and get a quote.
On the other hand, if you can open up the files and access all of them, your HDD has not failed but, you have a very damaged Windows installation. This also may be reparable, but again, you'll need to get it to a professional to fix it. Before you do that, though, make sure to copy all of your important documents, photos, videos, etc., to the test computer's hard drive or onto the removable media (SD Card, Flash Drive, etc.) connected to the test computer.
Apr 28, 2011 | Toshiba TECRA A6-EZ6312 (PTA60U05T00F) PC...
My computer doesnt want it connect to internet,, appear the connection icon but when the page try to open , it cant do
Please follow the steps provided below:
Q: Basic Wireless Troubleshooting
A:
The following steps will help determine if the wireless card in the system is functioning properly.
IMPORTANT:
Please go through all the troubleshooting steps. If the wireless card is functioning properly, please check the network configuration. Acer America can not assist with configuring the network.
Before you start:
  • Make sure there is a wireless router or wireless access point.
  • The wireless router/access point is plugged in.
  • Refer to the owners manual to ensure the wireless adapter is on (you can turn the wireless card on and off by pressing a clear button)
  • Contact the internet service provider to make sure ther account is active and the network is connected in a way that supports their configuration.
If the computer was working properly at an earlier time:
If the laptop was working fine, do a System Restore which rolls the system back to the last known working configuration. System Restore is located in System Tools under Accessories. Here is a link to explain the use of this feature:
http://support.microsoft.com/default.aspx?scid=kb;en-us;306084
To find the wireless network:
1. Click on Start winxpstart%20button.jpg then click on "Control Panel."
xpmenu.jpg 2. In the Control Panel window, click on "Network and Internet Connections."
3. In the "Network and Internet Connections" window, click on "Network Connections."
networkconnect.jpg 4. Once in Network Connections, right-click on the wireless connection then select "View available wireless networks"
5. If the wireless network is a secured network, please refer to the manual of the wireless router to make it unsecured for the purpose of testing the wireless network.
NOTE: Acer does not recommend leaving a wireless network unsecured and is not responsible for data accessed due to unsecured wireless networks.
6. If the wireless network is listed, the wireless adapter is functioning properly. If unable to connect to the wireless router, go through "Before you start" at the beginning of this article.
Mar 05, 2011 | Acer Aspire 5100 Notebook
Have a toshiba satellite 3000-x4 but can not connect to the internet
For Ethernet connection problems.
1. Turn OFF the laptop and modem. Unplug them from the power outlet. Leave them unplug and turn off for at least 30-60 secs.
2. Turn ON the NB and try to connect. If same thing, go to step 3.
3. Reset IE.Follow the steps in http://support.microsoft.com/kb/923737. If same problem go to step 4.
4. Do system restore.Follow the steps in http://support.microsoft.com/kb/948247. Try to connect.
For WiFi connection.
1.Press Fn+F8 to check if WiFi is ON.If turned ON and still not connected. Go to step 2.
2.Reset IE. If same thing go to step 3.
3.Do system restore. If same thing go to step 4.
4. Uninstall the WiFi driver.
a. Go start/control panel (classic view)/systems/click hardware tab/device manager.
Device manager dialog box will appear.
b. Click network adapter.
c. Right click on the wireless driver. Select uninstall. Do not delete the driver. Click OK.
d. restart the laptop.
e. Once restarted. reconnect to the network. then open IE.
Hope it works.
Feb 26, 2011 | Toshiba Satellite 2455-S305 Notebook
Hp 550 laptop is not starting and only blue light is on
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The power button could be bad.
5. The motherboard could be defective & needs to be replaced.
Sep 10, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
System hangs after 5 minute 0f os Ubuntu
The issue might be due hardware malfunction or lack of system performance or corrupt os.
perform hard drive self test:
Hard Drive Self Test:
1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
2. Shut down the computer if it is running.
3. Press the power button to turn on the computer.
4. Press f10 when the HP/Compaq logo displays.
5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
6. Select HDD Self-Test options .
7. Press enter to display a list of HDD/Self-Test options.
8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If test pass then perform below steps:
Improve system performance:
Follow the steps provided in the below url:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00815926
if persists, restore the ntoebook to factory settings.following below steps in the url
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703:
Mar 26, 2010 | HP Pavilion dv9000z Notebook
My laptop wont even turn on! how do i make it work?
OK! I'LL PLAY ALONG?
MAKE SURE POWER CABLE CONNECTED TO REAR OF LAPTOP/PLUG END IN SOCKET/TURN ON SOCKET/MAKE SURE POWER AT SOCKET?
OPEN LAPTOP/SHOULD SEE LED(S) SHOWING?
LOCATE SWITC/BUTTON/PRESS/SHOULD HEAR HDD STARTUP AND SCREEN ACTIVATE?
BATTERY MAKE NEED RENEWING IF NOT HOLDING CHARGE?
Nov 15, 2009 | Compaq Presario Notebook
I HAVE LAPTOP IBM THINKPAD T30 AND I WANT TO CONNECT HARD DISK 80GB OR MORE
  • Supported HDD thickness:
    • 12.5 mm for systems without the touch pad
    • 9.5mm for systems with the touch pad
  • Standard 20GB, 40GB, 60GB HDD sizes.
    Note:
    • The 60GB HDD orderable as marketing option part number 08K9688 has a height of 12.5mm and will not fit in the HDD slot of the systems with the touch pad installed. For these systems, it is only supported via the ThinkPad 2nd HDD Adapter for the Ultrabay 2000.
    • The 60GB HDD orderable as replacement service part number 08K9833 is 9.5mm.
  • Supports one additional HDD which can be used concurrently to offer expanded storage utilizing the Ultrabay 2000
  • S.M.A.R.T technology to issue an alert if a hardware failure is pending
  • ATA Bus Interface
  • 4200 or 5400 rpm
  • Although you can upgrade the HDD, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay 2000 HDD adapter is designed to provide this flexibility with a second HDD in the Ultrabay 2000 IBM says. I say if the OS recognises it and so does the BIOS, you're good. good luck, hope this helps.-jmattes p.s. I found this info on: http://www-307.ibm.com/pc/support/site.wss/MIGR-42218.html
Oct 17, 2009 | IBM ThinkPad T30 2366 Notebook
4 beeps 2373 laptop
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
IBM POST Diagnostic Code Descriptions
Code Description
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Colour/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Colour/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
Code Description
1 Short Beep System OK
2 Short Beeps Parity error in the first 64 KB of memory
3 Short Beeps Memory failure in the first 64 KB
4 Short Beeps Memory failure in the first 64 KB Operational of memory
or Timer 1 on the motherboard is not functioning
5 Short Beeps The CPU on the motherboard generated an error
6 Short Beeps The keyboard controller may be bad. The BIOS cannot switch to protected mode
7 Short Beeps The CPU generated an exception interrupt
8 Short Beeps The system video adapter is either missing, or its memory is faulty
9 Short Beeps The ROM checksum value does not match the value encoded in the BIOS
10 Short Beeps The shutdown register for CMOS RAM failed
11 Short Beeps The external cache is faulty
1 Long, 3 Short Beeps Memory Problems
1 Long, 8 Short Beeps Video Card Problems
Phoenix BIOS Beep Codes
Note - Phoenix BIOS emits three sets of beeps, separated by a brief pause.
Code Description
1-1-3 CMOS read/write failure
1-1-4 ROM BIOS checksum error
1-2-1 Programmable interval timer failure
1-2-2 DMA initialisation failure
1-2-3 DMA page register read/write failure
1-3-1 RAM refresh verification failure
1-3-3 First 64k RAM chip or data line failure
1-3-4 First 64k RAM odd/even logic failure
1-4-1 Address line failure first 64k RAM
1-4-2 Parity failure first 64k RAM
2-_-_ Faulty Memory
3-1-_ Faulty Motherboard
3-2-4 Keyboard controller Test failure
3-3-4 Screen initialisation failure
3-4-1 Screen retrace test failure
3-4-2 Search for video ROM in progress
4-2-1 Timer tick interrupt in progress or failure
4-2-2 Shutdown test in progress or failure
4-2-3 Gate A20 failure
4-2-4 Unexpected interrupt in protected mode
4-3-1 RAM test in progress or failure>ffffh
4-3-2 Faulty Motherboard
4-3-3 Interval timer channel 2 test or failure
4-3-4 Time of Day clock test failure
4-4-1 Serial port test or failure
4-4-2 Parallel port test or failure
4-4-3 Math coprocessor test or failure
Low 1-1-2 System Board select failure
Low 1-1-3 Extended CMOS RAM failure
Feb 19, 2009 | IBM ThinkPad T40 2373 Notebook
Toshiba Satellite M45-S331 Notebook Logo
124 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
