Hi, Maybe you deactivated it by mistake some laptop models have a button to activate and deactivate the mouse(touchpad) make sure yours is activated, if the problem is not that, then try re installing the touchpad drivers. You can find the drivers in the manufacturer home page.
Take some time to rate me.
You activated that feature yourself by hitting *3 you may want to use this when you go on vation so it goes directly to VM. #3 will deactivate this feature.
Fixed dialing is a network-based service which should not be active
unless you specifically ask them for it, perhaps it has been activated
on your account by mistake and another customer is wondering why it
doesn't work for him.
You would have to get in touch with your network
operator to deal with this.
However, it may be possible to activate/deactivate
it through the phone if your network supports this option. But requires
a Pin2 code that can ONLY be provided by your network
You
can go to Contacts > Options > SIM Numbers > Fixed Dial
Contacts > Options > deactivate fixed dialling > Enter Pin 2
code.
Otherwise, put your SIM card in another phone if
possible to see if you get the fixed dial issue still. If yes, please
contact your network for assistance.
There is a button that activate and deactivate the keypad check if when you clean the keypad you touch a button by mistake that deactivate the mouse and click it again.
My dear friend ,don't you activate progresive scan function by mistake because if you do it you gotta deactivate.
Try this turn on the dvd with no disc on the tray push for 5 sec the stop button.Good luck.
