If you were originally having a wild fluctuation in measurement at the
battery the voltage regulator would have been shot. I'm not sure of
what the condition was of the original alternator. But I would
definitely have changed the voltage regulator. A bad regulator can ruin
a battery and all sorts of other things. If you are now getting wild variations in voltage
1st Purchase and install a new voltage regulator. (probably about $20.00 these days.
Then check your new battery by doing the following:
1 Disconnect it from the truck's electrical system.
2 Charge it up using another vehicle and jumpers.
3 After disconnecting the battery from the jumpers, let it sit for a few minutes.
4 Check the voltage. If it is below 12 volts, the battery is shot. Replace it under warranty.
5 When you get the new battery, Install it in the truck and start it up. Then measure the voltages coming into the battery from the alternator and the new voltage regulator.
If all is well, your done.
If not. Pull the alternator and replace that.
Hope this helps,
Good Luck,
Mark
