I have a D946GZIS motherboard. It does not boot whenever i switch it on and press the power button. Also the power led is not glowing. What must be the problem..? pls help ..
Starting at the begining.
The wall socket, the plug, the cable, the power socket on the SMPS at the back of your PC, the SMPS, the Output connectors from the SMPS to the motherboard.
The power LED not glowing means that the power is not reaching the motherboard. Disconnect and reconnect the power connector on the motherboard. start. No start. Does the fan on the SMPS work? If yes then all components before the SMPS are doing fine. If no then most likely connection socket power cable to the SMPS may be the culprit. This has a lot of load on it. The PC and the monitor both take power from this socket.
the answer to your problem lies in the answer to my question whether the fan starts in the SMPS or not. If yes then there is no output from the SMPS and the SMPS need to be given the due attention and if no then there is no power input to the SMPS and various cables and socketc need that attention.
In case you need to and can remove and open the SMPS look for bulged or burst capacitors. If found, replace them. Those round cylindrical components.
Sorry,please explain more clearly.
" whenever i plug it in with out the power switch? and it has no view on the monitor "
You will need power !
