Acer Aspire 4315 Notebook Logo
Anonymous Posted on Jan 05, 2011
I install windows server 2008 softwaer but i have get notes you have not space
Anonymous
Level 3:
President:
  • Acer Master 2,246 Answers
  • Posted on Jan 05, 2011
Anonymous
Acer Master
Level 3:
President:
Answers
2246
Questions
0
Helped
515158
Points
7384
Your hard drive is not enough, change with the bigger hard drive
  • Anonymous Jan 05, 2011
    not inought space hard drive, change with bigger one
1helpful
2answers
System requirement to run crystal report v9 professional
System Requirements
  • PC with AMD or Intel based processors, Dual Core CPU, 2 GB RAM.
  • 3.5GB available hard drive space (for English only, 7.5 GB for all languages)
  • DVD drive (for DVD install only)
  • Microsoft Windows 7 SP1, Windows 8, Windows Server 2008 SP2, Windows Server 2008 R2 SP1, Windows Server 2012
  • Languages: Chinese simplified, Chinese traditional, Czech, Danish, Dutch, English, Finnish, French, German, Hungarian, Italian, Japanese, Korean, Norwegian, Polish, Portuguese, Romanian, Russian, Slovakian, Slovenian, Spanish, Swedish, Thai, Turkish
Technical Specs
  • Hardware Requirements: Intel Pentium III or equivalent processor, 256 MB RAM, 512 MB Recommended
  • Disk Space: 2 GB for default installation with English language, 4 GB for default installation with all languages installed
1helpful
I'm having 512mb of ram can install .net on this and please send details to install .net package in a system.
Hello For .Net Framework 4.0 following are the pre requisite:-
System Requirements Supported Operating Systems:Windows 7;Windows Server 2003 Service Pack 2;Windows Server 2008;Windows Server 2008 R2;Windows Vista Service Pack 1;Windows XP Service Pack 3 Windows XP SP3 Windows Server 2003 SP2 Windows Vista SP1 or later Windows Server 2008 (not supported on Server Core Role) Windows 7 Windows Server 2008 R2 (not supported on Server Core Role)
Supported Architectures: x86 x64 ia64 (some features are not supported on ia64 for example, WPF)
Hardware Requirements: Recommended Minimum: Pentium 1 GHz or higher with 512 MB RAM or more Minimum disk space: x86 - 850 MB x64 - 2 GB
Prerequisites: Windows Installer 3.1 or later Internet Explorer 5.01 or later
If you fulfill above requirement then go to http://www.microsoft.com/downloads/en/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
and click on download, you will found other instructions over there
Good Luck, do rate the solution if got help
I have an Ml 110 G5 Server, But i could not find the VGA driver for the Win Xp , kindly assist thanks Justin
Hi, I m really sorry to say that but you have a Server Product and its built to run Windows Server Series on it (or Linux / Novell Netware).
This is the list of compatible Server list
Microsoft Windows Server 2003 Microsoft Windows Server 2003 for 64-bit Extended Systems Microsoft Windows Server 2008 Essential Business Microsoft Windows Server 2008 Foundation Edition Microsoft Windows Server 2008 R2 Microsoft Windows Server 2008 Small Business Microsoft Windows Server 2008 W32 Microsoft Windows Server 2008 x64 Novell NetWare 6.5 Red Hat Enterprise Linux 4 (AMD64/EM64T) Red Hat Enterprise Linux 4 (x86) Red Hat Enterprise Linux 5 Server (x86) Red Hat Enterprise Linux 5 Server (x86-64) SUSE Linux Enterprise Server 10 (AMD64/EM64T) SUSE Linux Enterprise Server 10 (x86) SUSE Linux Enterprise Server 9 (AMD64/EM64T) SUSE Linux Enterprise Server 9 (x86)
Here is the link for Drivers
Try to use the Driver for Windows 2003.
It has a Matrox VGA as I know. If you know which Matrox series you have, then Browse here for the Drives: Matrox Graphics Support. Make sure that you choose the Exact Driver software which suites the System.
Note: Not every product has the Driver Software for Windows XP.
Please rate the answer! Thanks for contacting Fixya!
1helpful
How to install hyper v on dell 2650. Can Windows 2008 with hyper v be installed on a Dell 2650?
Yes, Server 2008 will install on the 2650 as long as you make sure you have enough RAM and hard drive space. Once you have Server 08 installed, you will have a to-do list to help with setting up hyper-v.
Good Luck
C2Solutions
I have tried x2 chassis and working memory but cannot get the full 12gb installed and runniing with Win 2008R2. it only takes x4 2GB sticks. Have tested all sticks in other machines and in same one...
Please see the below table to find you are on the right track.
Windows Server 2008 R2 Datacenter 2 TB
Windows Server 2008 R2 Enterprise 2 TB
Windows Server 2008 R2 for Itanium-Based Systems 2 TB
Windows Server 2008 R2 Foundation 8 GB
Windows Server 2008 R2 Standard 32 GB
Windows HPC Server 2008 R2 128 GB
Windows Web Server 2008 R2 32 GB
2k3 server is not supporting in cq40 compaq laptop please any one help me
If you are thinking of installing Windows Server 2003,then try to make sure that your system meets the following minimum system requirements: 128MB RAM and a 600MHz processor, and I recommend 5Gig HDD Free space.
But if it is Windows 2008 Server, then think of having this : 512MB of Ram, 10Gig of HDD free space, and an x86 processor with minimum speed of 1Ghz, or an x64 processor with minimum speed of 1.4Ghz.
Hope this helps you out .
Try to download Windows Vista Service Pack 2 KB9848465 and received this error code 800F0A0A. Thanks for any help...
Workaround
To work around this issue, uninstall the August 2009 Windows Vista and Windows Server 2008 Application Compatibility Update, and then install Service Pack 2 for Windows Server 2008 and Windows Vista. To uninstall the August 2009 Windows Vista and Windows Server 2008 Application Compatibility Update, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Click Uninstall a program under the Programs section.
  3. In the Tasks list in the left navigation area, click View installed updates.
  4. Click Update for Microsoft Windows (KB972036), and then click Uninstall.
  5. Click Yes when you are prompted to confirm the uninstallation.
    Note If you are prompted for confirmation or for the administrator password, click Yes to confirm, or type the administrator password.
  6. Restart the system when you are prompted.
If this helped you then please help me and vote kindly, thank you.
1helpful
WANT TO INSTALL WIN SERVER O/S IN COMPAQ LAPTOP CQ40-317TU
It all depends on your system specifications.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
