Hard Disk Toshiba MK1646GSX
I have recently bought Acer 4520 with 160 GB Toshiba MK1646GSX HDD
The windows XP is only detecting 72 GB C: drive. I am not able to utilise the balance HDD.
Please suggest solution
(additional info SATA setting is IDE.)
  • rubyrizza May 25, 2009
    Please help.
    Me too have just bought a Toshiba MK1646GSX External drive, however my Win XP PC can't detect it. Can anybody help me?
    Thanks guys,
    Ruby Rizza
Who have a toshiba mk1646gsx driver???
please send to me...
Posted on Oct 13, 2008
Change setting to SATA as this is a sata/300 drive.
Posted on Jul 19, 2008
Posted on Sep 21, 2008
My Toshiba mk4058gsx HDD is not detecting
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Nov 20, 2011 | Toshiba (MK4058GSX) 400 GB SATA Hard Drive
I am using a toshiba portege m400 and try to upgrade harddisk to 250 gb while installiing windows 7 hard disk is not detected.
maybe its not compatible to the laptop the hard disk that you purchase try replacing it with lower capacity hard drive then reinstall the windows 7 again
Aug 07, 2011 | SIB 250GB 2.5" SATA HDD Hard Disk Drive...
I have a Toshiba (MK4004GAH) 40 GB Hard Drive which was taken out from a Old Toshiba Laptop. I bought a 1.8" IDE casing with USB and connected to my new laptop....however, it fails to detect the HDD....
You have to make sure that you have connected the HDD in the right way. Please open it and ensure that you placed the disk rightly into the casing with each pin tapping the rightful hole, see the casing's small manual. Note also that the laptop has to detect the casing as well, so cross check the casing to ensure that its working.
Dec 03, 2010 | Toshiba (MK4004GAH) 40 GB Hard Drive
I am trying to replace vista with xp on my toshiba a205 5800. i have bought the xp disk but when installation gets to the point of transferring files to the hd, it says that no hard drive is present. i...
The reason why Windows XP installation CD cannot detect the hard drive is because your Toshiba has a SATA hard drive and the Windows installation CD does not have the SATA driver on the CD.
If you do not have the SATA driver then you can get around this problem. Please click on this link and follow my instructions :-
Nov 04, 2010 | Toshiba (MK1032GSX) 100 GB Hard Drive
Toshiba 500 GB External Hard drive cant be detected by windows xp
yes you could simply format the harddrive in Fat32 using your macos that would be the best solution but don`t forget to backup your data by copy pasting the files on your mac or something else and after that to move them on the external hdd again to be available on the windows machine
Mar 11, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
Hard drive detection
You should not need a driver for it. Assuming you are using XP or Vista, the disk should be supported directly by the OS.
Have a look at external HDD troubleshooting.
Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update:
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
How to install windows xp on new Acer Aspire L320 computer
you can set the partitions in f-disk on the start up disk of windows 98, reset partitions to 32, format c: drive, take out disk and put in windows 98 cd. and restart computer. your done. windows 98 cd will install. your up and running. please give me a fixya rateing. Thanks farren
Dec 20, 2007 | Microsoft Windows XP Professional for PC
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
1,779 people viewed this question
David Payne
David Payne
