Question about Zebra Eltron P310I Thermal Card Printer
Ribbon Breakage Every time I try to print a card the printer ribbon breaks. I looks like the card isn't making it under the printhead. So when the printer moves the card forward and rotates the ribbon the friction between the two tears the ribbon.
  • BANDIDO666 Nov 25, 2008
    ******* **** thing keeps braking ribbon and seems the belts are slipping or motors not stong enough to turn ribbon wheel just stops all time i am about to jump on it
  • 3 Answers
You can try to lower printhead setting values (color and black), if not resolved then try another ribbon, old ones trend to fail this way.
Regards
Posted on Mar 25, 2009
Printhead error #768
The print head problem occurs if the drain tubes being clogged and is preventing the pump from sucking the ink out of the print-head. It could also happens if the ink lines allowing air into it.
There are few troubleshooting steps in trying to fix this issue. Click here for a detailed checkup.
Oct 19, 2011 | Paxar Monarch 9850 Thermal Printer
Frequently, when printing a card, the ribbon gets stuck on top of the card and it goes under the exit roller, forcing the printer to stall. I then have to open the cover, remove the card, wind back the...
According to your problem, first check that you have put the card in the printer properly. These types of printers are very sensitive. It can make malfunction for a little wrong with card or also with bad quality card or printer.
Check the ribbon quality or change the ribbons which are not in good condition. Re prepare those ribbons in cartridge and then install the cartridge properly. Check the printer settings also and reboot it. Try this it will help you.
Jul 28, 2011 | Evolis Pebble 3 ID Card Printer Package...
The printer breaks the silver hologram ribbon everytime i print.it only break the silver ribbon when i do holograms
If your ribbon is breaking while printing a card, there area few things to look at.
  • Check that the printer driver has the appropriate ribbon selected. If a different ribbon is selected on the driver other than what you are using in the printer. Go into the driver and change the setting to the correct ribbon.
  • Another reason your ribbon may be breaking is because the "X" offset is set too low or too high, in other words the printing is beginning too close to the left side of the card, or ending too much to the right side so when the print head goes down to print on the card, the ribbon gets sliced because the print head and the edge of the card knife the ribbon. In order to eliminate this problem, increase or decrease the "X" offset value. I recommend a minimum of three digits up/down depending on the circumstance. For example: X-offset = 06...increase X-offset to 09. If the "X" offset is to high...EX: X-offset = 20...decrease X-offset to 17. Do not increase or decrease the value by more than 5.
  • If ribbon appears melted onto card, the print head may be damaged. Do not try adjusting. Immediately contact your re-seller or Zebra technical support.
  • If ribbon is breaking and nothing is being printed onthe card, contact your re-seller or Zebra technical support.
Dec 04, 2010 | Zebra P330i Thermal Card Printer
I have a zebra z6mplus the ribbon keeps breaking
You may have your contrast set too high. If it breaks as it feeds under the printhead (while printing) your contrast may be set too high.
You also could have a ribbon spindle issue. Are both ribbon spindles turning?
Jul 08, 2009 | Zebra Z6M Plus Thermal Label Printer
DataCard printer ribbon breaks
First, what color is it breaking on? Yellow, Magenta, Cyan, Black, Topcoat?
Next, I would do is clean all the rollers in the printer with isoprophyl alcohol (99% if you can find it, 91% is ok, 75% is you're in a bind). This is a common problem
Then, load the Printer Diagnostics from your print driver CD. In diagnostics, you can set the BASE POWER for YMC, K or Topcoat. The base power is totally different from intensity. As the printhead gets old, you may need to back off the intensity to keep the ribbon from breaking.
Lastly, take a look at the ribbon:
Is the image placed in the same spot of the ribbon on each panel or does it move (creep) higher or lower? This creeping action is caused by many things and would be best to be serviced by a technician.
Finally, printhead replacement. About $695 MSRP
May 26, 2009 | Datacard Group ImageCard Platinum Printer
Ribbon keeps breaking
It might be because the printhead is heating up too high, and burning the ribbon.
Try lowering the heat in the driver.
Dec 31, 2008 | Fargo Persona C11 Thermal Printer
Data card sp35 plus ribbon break
There could be either of the following issues:
1. Check the print head temperature to make sure that it is hot enough to transfer the ribbon to the card.
2. The surface of the PVC card may not be image compatible. Try another brand of card or opt to 60/40 composite cards for testing.
For technical assistance by blog for id card printers, see our blog at www.safecardid.com/blog/
Jun 20, 2008 | Datacard SP35 Printer
Breaking since I change printhead
Hi, i think you must to adjust tension of ribbon.Go to menu and find adjustmento for tension,and try to adjust to "-" or "+" value, in small increaments.Print card and if no results,try again.
BR
Dec 05, 2007 | Fargo DTC525 ID Card Printer
Oki 520 missing print
You have replaced the item which is commonly the cause- the printhead. The other possible problems are: a connection break in the printhead ribbon cable, which makes electrical connection from the driver circuitry to the printhead. Look for a tiny crack, especially along the edge of this ribbon cable. Another possibility is an electronic component defect in the circuitry which fires the printhead, or maybe a loose solder connection in the same circuit. Lastly, when you replaced the printhead, are you reasonably certain the replacement head didn't have a broken top pin or two?
Apr 10, 2007 | OKI MICROLINE 520 Matrix Printer
Breaking Ribbon
Ribbon breaking continuously is caused by 2 common problems. 1. The printhead is going down before OR after the card has passed through. You would know this when you open your cover, and unlock you printhead, is the break before or after the card? Try printing the test page from the driver. That doesn't print "Edge to Edge" so if this is the problem, it should not break. 2. The print head heat settings are too high. If this is so, you can change this on the printers menu panel. I can explain more information, once I know your problem.
Jan 15, 2007 | Fargo DTC525 ID Card Printer
Zebra Eltron P310I Thermal Card Printer Logo
391 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
