Question about Bunn BT10B Coffee Maker
Bunn coffee maker bt10-b is tripping gfci. I had leakage from the tank, and after fixing, the gfci problem started. I suspect the zig-zag wire that is wrapped around the bottom of the tank has some water inside
  • huskerkc Aug 14, 2008
    I've taken the coffee maker apart on mine to make sure it is completely dried out. After I let it sit for a couple of days I put it back together and it works fine for a couple of days and then it starts triping the GFCI again.
The heating element inside is problably broken. Thats what mine does. just disconnect it and you will see that cures your problem. You cannot buy parts for this. I have tried already.Junk
Posted on Aug 27, 2008
Our bunn coffee pot trips the gfci and leaks water out of bottom of unit, why?
the water maybe wetted some electrical parts or ur tank heater faulty
Jun 24, 2014 | Bunn NHB Coffee Maker
I have a BUNN BT10-B Coffee Maker that started leaking. I believe it it is the gaskets between the top trank and the heater. How do I het these gaskets new?
The seal kit is available free of charge through Customer Service at Bunn. If you will call 800-352-2866 and have the model and date code from the bottom of your brewer and we will be happy to assist you.
Jan 16, 2011 | Bunn BT10B Coffee Maker
Need the lid seal or gasket for a BUNN BT10-B
Please call customer service with the model and date code and we will be happy to assist you with this problem. The number is 800-352-2866.
Sep 14, 2010 | Bunn BT10B Coffee Maker
My Bunn VP17-2 coffee maker has started tripping the gfci switch when the heating element comes on. The unit is aprox. 7 yrs. Old. And has not done this before. Should I replace the heating element should...
Check the elements first, also check the hi-limit switch and the thermostat, then check the elements the machine might have been low on water at one point.
Jun 21, 2010 | Bunn VP17-2 Coffee Maker
I have a Bunn BT10-B coffee maker. I need the two rubber parts to replace the old ones which is causeing it to leak.
If you will call 800-352-2866 with the model and date code, we will be happy to help you.
Jun 15, 2010 | Bunn BT10B Coffee Maker
When pouring coffee it drips, also doesn't keep coffee hot
Hi - Any time I've had an issue with my Bunn BT10-B, I go to the website, www.bunn.com , and go to their Customer Service area. They have been extremely helpful and informative.
Aug 16, 2009 | Bunn B10 Coffee Maker
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Aug 09, 2009 | Bunn NHB Coffee Maker
BUNN Single Satellite commercial coffeemaker trips the GFCI
Sounds like the coffee maker has a leak which is causing a ground fault inside the appliance. A very minor leak (just water vapor even) can cause this -- one that would never show itself by running out on the counter.
I would suggest taking it apart and looking for evidence of a leak.
Apr 21, 2009 | Coffee Makers & Espresso Machines
Bunn BT10-B silicone washer
Yes, you can get a washer from your local Bunn repair shop. For a list of repair facilities in your area, go to www.bunn.com And yes, the heat is a problem, so you can't use just any washer.
Jan 24, 2009 | Bunn BT10B Coffee Maker
Bunn BT10B Coffee Maker Logo
305 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
