Back to:
Tags:
Olevia LT27HVX 27 in. LCD Television
No picture (by 4 users)
posted by 1641ken on Jul 10, 2008
the tv has power but there is no picture when you turn the tv on
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by CLKKB, posted on Oct 06, 2008
I have an OLEVIA 427V that was working well for over a year with cable input. Now it won't acknowledge a cable signal. Help!
Comment by tishd, posted on Sep 09, 2008
Olevia 32 inch flat screen. Every time I turn off cable box (DVR HD) and TV, it apparently drops all the channels. Every time I turn it back on, I have to do a channel search (and the auto does not work .. has to be stndard). This just started a week ago .. for the last year the thing has worked well. Help?
Comment by dgses, posted on Jul 20, 2008
Picture was dropping from component video source after warming up and then eventually (several days) all video sources (AV, TV, DVI, RGB) drop after warming up. Now video stays on for only several seconds before it drops.
Best Solution
posted on Jul 27, 2008
FixYa! (100)
LindaT2
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
Picture would not come on after turning it on. I have this set up as a monitor and connected to satellite tv. I rebooted several times and it came back once. I powered it off and it will not come back. It flashes but no picture.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on no picture:
I don't want to Accept this solution
Can you Help with these Flat Panel Televisions problems?
unit will turn on and then immediately the screen flickers...
This LCD TV has a split screen option. The right side...
I have a LT7HVX Olevia television So before the television...
I just hooked an hmdi cable to me tv from my cable box....
the picture keeps running off the screen after i took my...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
