Question about HP Photosmart C4150 All-In-One InkJet Printer
The screen shows "03284DD6"
I push all the buttons and nothing happens. When opening the door, the printer cartridges don't move to the far right position.
What can I do?
  • wilmaann Jul 13, 2008
    I received no help and found it difficult to figure out how to find an answer!
  • 813 Answers
Does the office jet 8500 have a power reset button ? paper jamed, i removed the paper but now nothing happens
Check the following Steps to fix HP Printer Carriage Jam :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 11, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
X4270 error 1200
Turn off power to the printer and unplug it from the back of the printer.
Insert the power cord back into the printer. You will hear some clicks and motors moving. Pull out the cord again when this happens.Open the cartridge bay by pulling the face forward and lifting the bay door up. The cartridge carousel most likely will not come to the center.By trying physically pulling the carousel to the middle (NOT BY THE RIBBON CABLE) ,if you can not pull it to the middle push it far right as possible. Listen for a click.
After pushing to the right and hearing a click you should then be able to pull the carousel towards the middle easily. Remove the ink cartridges and power up the printer again.You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay.Your problem is fixed.
Aug 27, 2009 | Lexmark X4250 All-In-One InkJet Printer
1200 error
trying physically pulling the carousel to the middle. (NOT BY THE RIBBON CABLE) If you can not pull it to the middle push it far right as possible. Listen for a click.
YAY problem fixed.
Hope this might helpful to you.
Please rate me if i am helpful.
Thank you.
Yboyandrei
Aug 22, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error #1200
if that doesnt help...
remove the shell from the black base, clean the goop from under the ink cartridges, put silicon on the bars after cleaning with alcohol, grease the gears sparingly, put it back together,
good luck
Jul 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
My Epson SX 100 is low on the three colours but when I open the top to get to the Cartridge Bay, the cartridges are not stopped on the right place for me to change them with new ones. They are stopped on...
Have you pressed the ink button to move the ink carriage to the correct position? Press the ink button to indicate each empty cartridge and then move it into the replacement position.
If it doesnt move you could always turn the printer on and as the carriage moves across pull out the cable or switch off at the wall socket. The carriage can now be pushed into the correct position. Push it back fully to the right before turning back on.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Error Message
Mar 02, 2009 | Lexmark X4270 All-In-One InkJet Printer
My message window shows error 1200. What does this mean? I cannot find a solution in my trouble shooting guide
The 1200 error is caused by a cartridge carrier stall. This can happen if:
  • The print cartridges are not snapped in correctly.
  • The encoder strip is out of place.
  • A foreign object is blocking the cartridge carrier's path.
Try this first step to correct it
You will receive an error along the lines of black cartridge missing. Open the bay, insert the cartridges, close the bay. if the error still persists Could be a timing belt issue, gearing or a jam, etc.
Typically, Dells are Lexmarks...
If you're comfortable with a wrench, have a look here:
http://support.lexmark.com/cgi-perl/...ocid=ENUS23485 .hope this solves your problem .appreciate by rating this as fixyaa
Sep 30, 2008 | Office Equipment & Supplies
HP Officejet 7410 All-in-one No Power Light
Turn the printer upside down right underneath where the cartridge station is you will find a small white gear...sometime it may be covered with a blue rubber cover.
when you turn the gear ..the barrier in front of the cartridge will go down.
Then do a rest on the printer and then install it.
Jun 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Erropr code #1200 Lexmark X4270
Tried what blkghost suggested above but had to tweak his advice slightly.
YAY problem fixed.
Nov 02, 2007 | Lexmark X4270 All-In-One InkJet Printer
HP Photosmart C4150 All-In-One InkJet Printer Logo
304 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
