Question about Sharp Audio Players & Recorders
Stereo model cd-ba1600 cd draw will not open reads error 0201.How do I correct this?
  • dmatthews109 Jul 11, 2008
    I am unable to open cd tray to load a cd.Advise I have received I have tried already,think I will junk the unit.Thank you for your usless help.
  • 4,889 Answers
Most of the CD drives will have an emergency eject hole. A small hole next to the Eject button. You can insert a ball-pin orr some other object into that hole and keep shoving while repeatedly pressing the eject button. Let me know if it worked. If it doesn't then i will give you instructions on taking the unit apart.
Posted on Jul 11, 2008
  • 1,512 Answers
Hi
The player may have a perished or slipping load belt. Sometimes this can be resolved to get a disk out by jiggling the drawer a little as you attempt to unload. You will
need to replace the belt.
If the drawer mechanism has been forced, then it ,may be jammed, preventing the tray from opening. If the disc has become dislodged this may also be jamming the tray.
If you are ok with mechanical things you may be abl to dismantle and sort out th problem. If no, then your local repair guy will be able to help you. Enter you zip code into the fixer finder. :)
regards
robotek
    Genius:
  • 2,035 Answers
This is faulty tray unit on the player which is jammed you need get it to service in local audio player service center to fix the issue and you can use this player again.....
  • Sharp Master
  • 13,433 Answers
The cd tray motor may be broken or stuck, You would have to take it apart and have a look around what is causeing the problem.
0201 does not say anything to me, but obviously its related to the cd tray. To fix it, take it apart and find the problem.
Does the tray try to come out? or does it just sit there as if noting has been pressed?
  • 2,427 Answers
There is a small hole in the cd draw, insert a straightened paper clip in it and push,,
If you model does not have this,
1.) remove the top cover,
2.) loacte the Cd Holder (a Rount Disc Plasticem attached to the sides)
3.) remove the holder
4.) Lift out your disc,
The error code suggest a jammed draw or damager motor
When you remove the disc, slide the lens all the way back and gently press the Rount Spinner (THAT FITS IN THE CENTER OF THE DISC) down , then push the draw foward and back till you hear a slight locking sound, Turn on the power and check if the draw opens. If it does turn it off , re assemble.
If that fails check the cd draw motor or band, Replace as necessary,,
I'd suggest you take this to a certified Tech if you are unable to perform the above operations.
    Genius:
  • 1,847 Answers
Try open the top cover and take the cd out.
My CD Player Draw Will Not Open
If there is a co in it then it probably fell out and is stuck... especially if it was shaken.... unplug the unit.... remove the screws holding the case together and open it up
Oct 16, 2014 | Electro Brand Nostalgic Stereo CD Music...
Jvc stereo tray error fs-s77
Model number is not correct. Give the JVC model number
Sep 15, 2013 | JVC AM FM CD DET FACE CAR STEREO
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
When i try cd it keeps writing error.and reject every cd plates i insert.it was playing normal 2days ago.pls what do i do when error notice appear.the car is honda 2003 model coupe.thanx
Unfortunately 90% of the time when you get error codes from the CD player/changer it means that there is a mechanical failure in the CD player/changer unit itself and it usually requires CD player/changer rebuild or replacement...
First make sure you have entered the correct anti-theft code. If battery power has been disconnected recently than the stereo display will read CODE if the incorrect anti-theft code is entered the display will read ERR1 thru ERR3. If this is the case you'll have to get the correct anti-theft code. Note; If you enter the incorrect code three times the stereo locks up. Disconnect the battery for more than 30 seconds and then retry.
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 2003 Honda Accord
1998 Honda Accord EX stereo/CD player has Code E on the screen... What is the cause of this and what can I do to fix it?
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam and cause the player to display error codes E-01 thru E-07. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 1998 Honda Accord
Stereo reading error a/o on screen
This is a very broad error code meaning electrical or mechanical problem. I'm sure you've tried turning the ignition on and off. If toggling between radio and CD doesn't help, its time to check for loose connections or open up the head unit.
Jun 29, 2010 | Pioneer DEH-P2900MP CD Receiver...
Disk placed wrongly and cannot be read.
  • shut the computer off..
close to the eject button you will find a small pin hole
straighten out a paper clip and push it strongly into the hole and the drivr will pop open.. even if just slightly,, just pull out the draw and remove the disc.. close draw firmly and turn on pc..
the pin hole is there trust me..
Mar 18, 2010 | Acer Computers & Internet
Error Code Displayed When CD Inserted
Error 01 is normally on most machines to say it cannot read the discs. Could be dirty laser or a defective one. Must open to make better diagnosis.
May 12, 2009 | Jensen MSR4050G CD Player
No Disc error, won't read any CD
rca does not sell just the laser it sells the base assy. it consistos of the laser & the spindle motor on the metal base. no circuit boards, thoes you will need to remove off of the old one. the list price from rca is $136.10 CDN. replacing the part is not too hard, but take a little time. good luck.
Feb 13, 2007 | RCA RS2501 Shelf System
156 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
