Thanks. I think it is the 520, but I cannot be sure as the PC is at my ex-wife's home. Yet in my particular case it no longer matter. We have it working. The network controller only had to be selected and at this point I cannot recall exactly how I did it, but once restarted it has been working fine.
As for lahibnar, and my choosing inappropriate answer, sorry lahibnar but not many folk choose to look up a program which will automatically interpret different languages, so you'll need to find a program which does the reverse, interprets your Input as you type. I haven't the foggiest what you wrote above.
Same Problem
Jan 22, 2009
-   Sorry about the double post I didn't realize it would post unless I signed up since when I tried to post I was asked for a login name. I guess I've got some learning to do on this forum.
-   I wonder would you mind explaining how to locate system model number or Dell part number? There seem to be more than one number on the board & from within it is difficult to know where to look.
Oh no I just went to enter my email address & when it wouldn't let me I backspaced to try again & everything I had added to this to further explain my problem was missing, so I'll start all over again only this time I'll Copy & Paste if I have the same problem.
OK we wiped the drive, reloaded the full version XP Home & all works except for internet connectivity. Assuming that there is no NIC card, as the only 2 internal cards are the modem card by Conexant (RD01-D860) with two RJ-11's and the Nvidia graphics card, I believe I have a similar need for mother board drivers. Does this make sense? The Comcast tech told us to check online for the motherboard or NIC model numbers but I think now that I have the wrong motherboard number.
The only problem I am having is I cannot access the internet. A tech at Comcast told us to download drivers for the NIC card or the Motherboard. Since there are only two boards internal, one a modem board by Conexant & the other a Nvidia graphics board I must assume the driver s we need are for the motherboard.
The drive was wiped & we loaded the full version XP Home & all but the broadband connectivity is working fine.
Rank: Guru
Dell Staff
Expert
Rating: 89%, 324 votes
Hi
E210882 is a number found on more than one Dell System Board. Dimension 8400 and 4600 come to mind. Possibly there are more. Secondly, E210882 is not a Dell Part number (DP/N or DS/N). While Dimension 8400 is a 775 socket, Dimension 4600 is a 478 socket. So they don't fall to the same family.
In any case the network controllers used on Dell System Boards are Intel and Broadcom.
To proceed, at least provide/confirm the system model. If this is not available, give the Dell Part Number.
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet,...
(More)
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet, ik trachte ook met opstartschijf.... Ik zie dat bios/cmos? niet opstart, op mijn scherm krijg ik enkele seconden "in power safe mode, press any key" ik probeerde al veel, batterij eruit gehaald en vernieuwd, videokaart gewisseld, scherm gewisseld, alle plug ins nagekeken,enz.... Kan iemand zeggen wat er aan de hand is en hoe ik het kan verhelpen, ik trachtte ook het oude geheugen teurg te plaatsen, dit zonder resultaat mvg Jan
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard...
(More)
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard drivers to download direct so i can put on disc to correct
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan...
(More)
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan amable de pasarmelo se lo voy a agradecer mucho.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
