Question about Kenwood KDC-MP335 CD Player
Car audio i need to know wat the remote wire is to be hooked up to it and where it goes. coming from my aplifier
It goes to the blue wire with a white line on it. that will turn ur amp on when u turn ur stereo on .turn stereo off it will turn amp off.
Posted on Dec 27, 2008
On the back of he cd player is the wire harnest there should be a SOLID blue wire on there take the remote wire connect it to that and run it to your amp and put it where the amp says remote. there is an easier way you can hook up your power to the amp then take the remote wire and just run it directly to the power wire on the amp you should only need a couple inches of wire and it will work fine
Posted on Oct 07, 2008
I bought a used pioneer car stereo/cd player for my boat,battery wire marked, acc marked ( what does that wire up too?? ) & remote wire?? wat does it hook too ??
battery(yellow) goes to power that is ALWAYS on.(straight to + on batt) red or acc goes to accessory position of ignition key. (if no acc then wire to ign on(unless you want to listen to it with boat off then wire to batt + also but deck will be always on. REM is remote switch wire(gets power when h/u is on) and is used to turn on the amplifier if you have one or to make electric aerial go up. if you don't have either then don't worry bout it. leave it off but tape up the end.
Jun 18, 2010 | Car Audio & Video
Red light
try runing the remot to the battery and c wat it does
May 14, 2010 | Dual 2-Channel Bridgeable MOSFET Amplifier...
I have the Kd-S550, I need the wire connections . thanks
yellow goes to positive of the battery
red goes to the acc of the ignition(0volts whn car is off 12volts when car is on)
blue goes to a amplifier remote terminal if you have on if not the tape over the exposed copper
black goes to ground
the white of the speaker is that coming from the radio or from the car?
if it is from the radio then connect it to one side of the speaker
you need the cars radio wiring instructions and radio wiring intructions and double check each wire
Jan 03, 2010 | JVC KD-S550 CD Player
How do I hook up speakers and an amp
Big red cable goes from + on amp to battery. Then the black - wire goes from amp to body ground (unpainted ground) The Blue remote wire goes from amp remote to the remote wire on back of the cd deck.
Then, the rca jacks go from Rear Audio Out Jacks on CD deck to the Audio IN Jacks on amp.
Speakers have Red + and Black - which match up to screws on amp.
P.S. Make sure fuse is out while hooking everything up.
Jul 09, 2009 | 1999 Jeep Cherokee
Help asap
hook blue wire to ur radio to amp remote
Feb 12, 2009 | Sony Car Audio & Video
Help with jensen vm9021ts
To ground a wire is just to pretty much hook it to the negative battery terminal. And since, the body of your car is directly tied to the negative battery terminal, just attach the wire to the body of your car. Some times there is already a ground run and I would typically use one of those. In your case I would just run it to the ground behind the radio. The black wire you hooked up for the power of the head unit is what you need to wire it to. Let me know if you need more help. Good luck
-Andrew Hawkins
May 31, 2008 | Audio Players & Recorders
SONY CDX-M8800 STEREO
Red (accessory wire)- goes to hot wire that can be turned off.
Yellow (constant wire) goes to your cigarette lighter
Blue/white is your amplifier remote turn-on wire.
Probably have green and green/white- brown and brown/white-white and white/black, and another color for speaker wires.
You can hook one pair up to your cd player and find out if it's hooked up to the right speaker channel.
Orange (remote antenna) wire.
Apr 20, 2008 | Sony CDX-M8800 CD Player
I need help hooking this up
"is the got two wires in the ground and remote turn on wie"
Can you be more specific about the wiring...where the two wires are connected to and where they come from, and I'll try to help you.
Mar 29, 2008 | MTX Thunder 895 Car Audio Amplifier
Wiring up an amp
You must to connect remote swith wire from your CD player to amplifiers remote switch wire. It needs because when you turning player off its turning off your aplifiers power and wise versa.
Jan 27, 2008 | Car Audio & Video
Kenwood KDC-MP335 CD Player Logo
167 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
