Question about AOC Computers & Internet
Monitor issue I am having a problem with my monitor. I nthe cevter of the screen is a blue box with the term "Out Of Range" notice in side th e box. My entire screen is very fuzzy and out of focus. The model number is 912Vwa-1. Any help would be greatly appreciated
  • 165 Answers
Open Control-Panel-Display, click on "Settings tab".
Use the slidet to change resolution.
Your monitor should be 1440 X 900.
Click "Apply"
If screen is OK, click "OK" on popup prompt.
if display goes dark, wait 15-20 seconds and it will return to where it was before.
Also: you can click the "Advanced" button
Click on "Monitor" tab.
Adjust "Screen refresh rate to 60 hz or 75 hz.
Posted on Jul 10, 2008
Can i connect two monitors to a nvidia geforce 315 card so as too use two monitors
hi,
yes the 315 desktop card does have multi monitor support. you may however need an adapter for one monitor as it only has one dvi ,one hdmi and one vga.
so you can hook up any 2 as a combination but they have different plug configurations to do this
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Sep 16, 2011 | Computers & Internet
A blue box on desktop appears, says 'Out of Range'
Try connecting a different monitor and if the issue does not persist then the other monitor/display is already defective. As per the description that is provided, the problem is with your Display/Monitor.
Aug 15, 2010 | Dell Computers & Internet
Has a blue dialog box that says out of range
Hello
It sounds like you have two separate problems.
The first one is the "out of range" issue. This means you are trying to display a screen resolution that is too high or too low and your monitor cannot display any image. Reboot your computer with another monitor or into safe boot mode and change the resolution to an industry standard (800x600 / 1024x786) and then see if your monitor will display the image. Once you can see the image on your monitor, you can make adjustments and it will automatically revert back if you cannot see the new display settings.
Update your video graphics card drivers to get the best possible resolution.
As for the buttons on the front of the monitor not working, this may be caused by the "out of range" issue above. It could also indicate that your monitor may be going bad. Try the above steps - if you get no image from the monitor, try moving the monitor to another known good computer and see if the button functionality works after it displays an image.
May 04, 2010 | AOC 193FW LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Out of range
If there is no hardware issue, this message indicates that your PC's Screen resolution settings (and/or Refresh Rate) are above the capability of the monitor. This can be corrected by booting into Safe Mode (F8) and lowering as necessary.
Good luck and kind regards.
Feb 05, 2008 | Gateway FPD2275W LCD Monitor
FP531 Computer monitor operational manual
Monitor Help The size is an important factor of the computer's running resolution. When picking the resolution.
Cant find your maual on sites, contact your computer manufactor for the maual.
Dec 19, 2007 | BenQ LCD Power Adapter for FP951 Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
Benq monitor fp51g
What's the owner's manual say that means?
Jan 13, 2007 | BenQ FP51G 15" LCD Monitor
Computers & Internet Logo
204 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
