Question about Zenith Televison & Video
Zenith model: H27D35DT8 using "concierge" controller model LP702. Cannot access Installer Menus - Manual says "Hold Menu key down for about 8 secs until menu changes - then enter code..." When I hold Menu key down the menu never changes; it simply disappears... HELP!
    Genius:
  • 1,226 Answers
Did you try resetting the setting.? You have to do is unplug the power outlet from the wall and then wait for a couple of a minutes to let automatically hard rest.
and then plug it in and then test,
melnavz
Posted on Jul 10, 2008
  • 813 Answers
    Genius:
  • 1,665 Answers
Can I do a Factory default reset on a Zenith Concierge Series H2530Y7 Model Television without the remote control?
ZENITH SC652 Concierge Commercial TV Remote Control buy a master remote then,
  • Press the "Power" button on the Installer's remote control to turn on the TV.
  • 2 Press and hold down the "Menu" button on the remote for about six seconds until the menu disappears.
  • 3 Press the "9," "8," "7," "6" and "CC" buttons in succession. This resets the TV to factory default settings
  • Read more : http://www.ehow.com/how_7393497_reset-zenith-concierge-television.html
    Apr 24, 2015 | Zenith Televison & Video
    Hello, I have a Zenith Concierge model number
    http://www.manualsdir.com/manuals/228916/zenith-concierge-h25f39dt-concierge-h24f39dt-concierge-h27f39dt.html
    Jul 02, 2017 | Televison & Video
    Codes to check with Zenith brand TVs are: 0287,0281,0288,0285. Try these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
    http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy In case of service manual, I've it with me, but cannot upload it by this window as it is in PDF.
    In case of service manual, I've it with my system library, but cannot upload here by this window, as it is in PDF.
    google.com/+GopakumarGopalan
    Nov 02, 2013 | Zenith C27A24T 27" TV
    How to access to life fitness treadmill 95te menu
    Hold down the PAUSE Key and press CLEAR Key twice. Continue to hold the PAUSE Key until the SERVICE MENU appears. Use the Speed UP/DOWN key to scroll through the menus and the ENTER key to make a selection. Once finished CLEAR button twice will reset the machine for use.
    Oct 09, 2013 | Life Fitness 95Te Treadmill
    Have bought a second hand philips 28pw6506, it has no remote control. Do you know how to change the aspect ratio or size of picture on screen? Have looked through the menus with the button on top of the...
    Hello
    To change its picture aspect ratio, you have to go to its menu. As you haven't its remote control there is an option for that, mentioned in its user manual. I hereby send it to you. Do the same and access the aspect ratio.
    The television set has 4 keys which are located
    on the front or the top of the set depending
    on the model.
    The VOLUME - + (- Vol +) keys are used to
    adjust sound levels.The PROGRAM - + (- P +)
    keys are used to select the required programmes.
    To access the menus, simultaneously hold down
    the VOL- and VOL+ keys.The PROGRAM - +
    keys may then be used to select an adjustment
    and the - VOL+ keys to make that adjustment.
    To exit from the menus, hold down the 2 VOL-
    and VOL+ keys.
    Note: when the Child Lock function is activated,
    these keys are unavailable
    OK.
    Dec 21, 2010 | Philips 28PW6506 28" TV
    LG RU-27FB30C. It's blocked.
    http://www.newtvremotes.com/Mfrs/Zenith/ZenithTV/LP702.htm
    VISIT THE ABOVE LINK AND ALSO SEARCH
    RU-27FB30C on internet and you will get the manual
    Jan 20, 2009 | LG RU-27FB30C TV
    Concierge Hotel TV - Volume Control
    If there are no chasis numbers on the outside you may want to open the cast and check for numbers there. Then you might be able to google the number and find a manual. some TV's willl enter the menu or rest by pushing two buttons at once on the set. This could change your channel selection however.
    Nov 14, 2008 | Televison & Video
    Adjusting TV Volume
    Hi Joe,
    If you do not have it available, you can access the user guide for this product at http://www.zenithservice.com.
    Page 29 should be the beginning of instructions on using the installer remote. Reference the chart to find the menu line for start channel/volume. Depending on your set, this may be on line 10 or 11. You also may find options for minimum or maximum volume, as well as many other settings using this chart.
    The next page gives specific information concerning this feature. The number you enter into this menu line determines the channel (with 0 being Aux and 255 turning the feature off). Volume is determined by actually setting the volume when on this menu line.
    Hope this helps,
    Jason,
    Go Ahead. Use Us.
    Jul 31, 2008 | Televison & Video
    Zenith TV not programmed for home purpose
    If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
    I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
    To go to installer menu (different from regular menu):
    - Hold MENU for 8 seconds.
    - Press 9, 8, 7, 6 and ENTER in the sequence.
    You should be in the installer menu now. There should be a line that looks something like this:
    03 VERT POS 13
    Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
    CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
    START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
    You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
    I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
    May 26, 2008 | Zenith SC652 Remote Control
    Zenith Concierge H25W35DT 27"
    The CORRECT answer is you must purchase a LP702 remote. Google it to find one to buy. You must unlock channels and program the channels fresh.
    Some standard zenith remotes allow you to reset the tv by popping off the cover of the remote and pressing an unmarked button.
    Mar 09, 2008 | Zenith C27A24T 27" TV
    Televison & Video Logo
    369 people viewed this question
    Top Zenith Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
