Question about Kitchen Appliances - Others
Simplicity air conditioner
On the digitl display E1 and then it shut off
  • monberge Aug 06, 2008
    I have the same problem the only thing is it's not shutting down. Can someone tell me what it means? I did shut it off and when we pluged it again it was still the same.
I had an e1 error, the fan was spinning but the compressor dosen't.  I don't know witch step i made fix the problem but try it.  I unplug the air conditioning for few minutes, unplug the control panel, get every things  back and it's work fine.I wish that can help youFrançois
Posted on Aug 10, 2008
My air conditioner showing on the display is E1
The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
How to Fix an Air Conditioner When It Gives You an E1 Code eHow
Jan 24, 2016 | Heating & Cooling
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
Comfort Control Center 2. Why is E-1 error displayed?
[PDF]Customer assistance for air filters cleaning (E1 code)
www.sharpusa.com/.../air_man_AFS100FX_S120FX_S125F...
Sharp SolarCustomer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners. The display will indicate an E1 code and not allow the unit to operate until the ...
Sep 08, 2015 | Dometic Rooftop RV Air Conditioner
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
May 28, 2011 | Sharp AF-S120FX Air Conditioner
E1 ERRORE COMES IN M Y AC WHICH REASONS
panel.
button.
  • Date: 5 Aug 2005 06:33:46 -0700
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error Code
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Mar 01, 2011 | Heating & Cooling
Ei flashing display unit power cutoff
E1 MEANS FILTER CLEAN AND THEN CHECK IF STILL ON THIS IS ASOFTWARE PROB CAN BE DONE ONLY BY THE SEALER SUPPORT.
Aug 31, 2009 | Sharp AF-S85FX Wall/Window Air Conditioner
E1 code
Use a universal remote (like the one for a TV) to turn on and to adjust settings. I was some what doubtful, but after trying my universal remote, my air conditioner started working.
Jun 18, 2008 | Sharp AF-S120MX Air Conditioner
Kitchen Appliances - Others Logo
721 people viewed this question
Top Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
