Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
External hard drive don't install
Wd western digital my book external hard drive
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Why is there a question mark on my WD My Book 500 external Hard drive short cut?
Wow, Im amazed at the guy who threw his WD into the freezer for a week after a fatal crash and was able to get most of his stuff back! I was so frustrated after my second WD crashed that I gave up and used it as a door stopper. I was too bummed out to even bother returning it for an exchange, and when I did think of doing that, it was too late. I decided never to buy WD again, their drives are pure junk!
Reply to:My Computer does not show: Western Digital My Book Essential Edition 500 GB external USB hard drive)
Jan 03, 2012 | Western Digital 500GB My Book World...
I HAD Western Digital My Book Essential 1TB External USB 2.0 Hard Drive ON M PC AND I CONECT WESTERN DIGITAL MY PASSPORT AND RUN THE AUTO FROM THIS SOMETHING LIKE WD SMART.... AND NOW MY Western Digital My...
Your WD HDD have been attacted by viruses for your computer or outside computer where you used it last. Make sure that you have an up to date antivirus software, scan your computer or the external hard drive, explore your computer, go to tools - folder options under view files & folders select show hidden files and folders apply and ok it.
May 18, 2011 | Western Digital My Book Essential 1TB...
How to play music straight from my Western Digital My Book Essential 1TB without having to load it on my computer first.
Set your itunes drive to the external WD drive, easy. Itunes -> Preferences -> Advanced -> Store Location -> Set to your external drive
Feb 15, 2010 | Western Digital My Book Essential 1TB...
WD my book essential not working on windows
pls i really appreciated if you help me to find a free driver for my wester digital external hard drive 500 gb pls send it to my email how do i get a free drive .... my email: deejhay17@yahoo.com
Jan 22, 2010 | Western Digital My Book Essential 1TB...
Western Digital 1 TB External Hard Drive and BSOD
perhaps the new hard drive is bad western digital software is junk take it back and get seagate external w/freeagent on it
Dec 31, 2009 | Western Digital My Book Essential Edition...
Lost my installation CD for my Western Digial external hard drive
WD My book does not need driver to run on Windows, however you can download software for all Operative systems here:
My Book
If the direct link does not work, start from this page to locate the download: WD Support > Downloads > Select Product
May 30, 2009 | Western Digital 500GB My Book World...
Western digital wd 500gb external hard drive not showing the icon
Doewnload Testdisk and run it to see if it can find a boot sector.
Oct 04, 2017 | Western Digital 500GB My Book World...
Ibm t43, xp pro won't recognize my WD my book
please write down the error and contact me now
anaesarora online
Feb 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
Jan 26, 2009 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
151 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
