Question about SanDisk Sansa e260 MP3 Player
Mp3 player won't turn on/won't charge
It won't turn on and it also doesn't do anything when I plug it into the USB port,
  • marklconway Aug 28, 2008
    It won't recognize my player and if I go into device manager and uninstall it. I plug the Sandisk back in and I get the "problem occurred while trying to install device".
  • Anonymous Aug 31, 2008
    will not recognize player when i plug into usb port not charge or anything
If you Sansa won't turn on, press and hold the main menu button at the same time you turn it on. Worked for me.
Posted on Oct 18, 2008
Make sure the hold switch is in the unlocked position. otherwise the player will not charge or be recognized w/ the USB port plugged in.
Posted on Aug 31, 2008
  • 4 Answers
SOURCE: centon digital mp3 player problem
You might try reformatting the disk in your computer. if that does not work, contact Centon...this device has a 1 year warranty. ... you will need the receipt.
Posted on Jun 02, 2008
SOURCE: RCA Pearl TH1101A MP3 player not charging battery
it dose not recharge you have to replace the battery, even if you connect it to the computer it still won't rechage
Posted on Jul 24, 2008
  • 55 Answers
SOURCE: Sansa scan disk mp3 player
hii :
follow me --->>
1/my computer
2/ click twice on removable disk "F: or E: somtimes "
3/ delete & dowload whatever u want
dont forget rating this post if this is not helping u tell me so i can help u further .
Posted on Aug 21, 2008
SOURCE: Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site ( To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
Posted on Nov 17, 2008
SOURCE: just purchased base MP3 player won't charge
where is the reset button in sandisk sansa c150 mp3 player
Posted on May 07, 2009
Won't charge when plugged in to USB
Often the problem is the USB cable or the plug.
Make sure the USB cable is plugged in firmly, all the way on both ends. If it still does not charge, try using a different USB port on the computer or laptop. If that fails to solve the problem then get a new USB cable.
If none of the above solves your problem then your device is defective.
Jan 13, 2013 | SanDisk Sansa Fuse MP3 Player
Coby touch screen mp3 won't plug into anything
I use one of my other usb cords for my amazon and it works fine
Sep 23, 2012 | Coby MP828 MP3 Player
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
Won't come on after charging in usb hub
Depending on how long you've had the player, the batteries may need replacing.
I have seen a problem where the computer would not recognize the player and would not charge it, however.
First, I recommend trying to charge it directly from the computer USB port (not the hub) if possible. If that doesn't help, try reinstalling the software for the player to see if the computer will then recognize it and allow charging.
If neither of these fix the problem, it's probably time to replace the batteries.
Jul 13, 2011 | MyMusix PD-6070 MP3 Player
My onxy mp3 player won't charge despite being plugged into my USB port for hours
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2011 | Mach Speed TRIO Onyx MP3 Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
RCA M4002 mp3 does not turn on.
Download the latest firmware upgrade from to restore the player. The firmware upgrade file will be on the "Download Upgrades" section of the website.
-Tha Mp3 Doctor
Dec 27, 2008 | RCA OPAL M4001 MP3 Player
Charging the coby clip 1gb m582 mp3 player
the manual says something about turning the player on when inserted into the usb port so it  can charge
Jan 06, 2008 | Coby MP-C582 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
42 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
