Question about Ovens
Samsung SRS615DP Refrigerator
The temperature displays -16 and 3 degrees. After approx 10 hours the freezer display flashes. It is obvious that the temperature is higher than display indicates. Turn off the power and on again and it displays 4 and 14 degrees and the compressor cuts in and brings the temperature down to setpoint. It seems after set point is achieved the compressor does not start again as temperature rises until supply voltage is removed and then reinstated.
Moovonna
  • 3 more comments
  • moovonna Jul 10, 2008
    Why is the temperature indicated as -16 and 3 degrees C when it is not correct. It indicates correctly when the power supply is toggled off then on.
    This refrigerator does not have a manual dial control Thermostat but a digital display of temperature.
  • moovonna Jul 11, 2008
    The fridge has more than the recommended clearance around it.
  • moovonna Jul 16, 2008
    Fan spins at first as fridge chills at first. fan stops after achieving correct temperature and is slow to restart resulting in a warm fridge.
  • moovonna Jul 19, 2008
    The frige can be working well and then after the door is opened the fan does not start again when door shut.
  • Ovens Master
  • 19,396 Answers
The temperature indicated is wrong because the thermostat sensor is faulty.
The faulty sensor (thermistor) send wrong info to display, and as it is also a thermic switch it turns off the compressor before it reaches temperature.
Insert model number here and get replacement part. On the website you also find info on replacement.
Posted on Jul 14, 2008
  • Ginko
    Ginko Jul 15, 2008
    you need to replace the termic switch. Many fridges have Warranty 1 Year on parts and Labor · 5 Years on sealed parts.
    Contact Samsung to get replacement parts and check guaranty terms
    Sergeant:
  • 275 Answers
I think you should approach the manufacturer website www.samsung.com. they may provide you assistance like e-mail, contact number, online chat services....
Posted on Jul 16, 2008
    Sergeant:
    Champion:
  • 230 Answers
I think the problem is with your thermostat , so check that and if needs change that
Posted on Jul 19, 2008
  • 105 Answers
There may be some problem with the sensor in the system.or the display is affected by some problem which fails the system to show the actual temperatures.so for more details visit samsungs website or seek the advice of a mechanic
    Sergeant:
    Champion:
  • 417 Answers
Its Your thermostat sensor it is faulty You will Need To Contact The Manufacture
  • 2,427 Answers
Did you check if the fridge is gassed propperlay or if the fan inseide it is spinning , please respond to these questions..
Posted on Jul 15, 2008
  • Rishi Roshan Ali Jul 16, 2008
    Chech the thermostat (thermositor) I'm betting its manfunctioning.. It will proberally need to be replaced, You can hold a multimeter to and check the voltage as the fan spins, wait until it stops and the fridge starts to warm up and then check it again, basically it should keep current flowing when the fridge aint cold enough, it it wams up it should start sending ,more current to cool it down.. But this isnt the case, it isnt sending any so the fridge begins to warm up..
  • Rishi Roshan Ali Jul 19, 2008
    There is a small push sensor or switch on the door frame that when the door closes it closes the circuit. chect to see it isnt shorting or is working. you can push it in with your hand while the door is open, the fan shoulod come back on. HOLD down the switch and plug the fridge in, if it comes on then the switch is fine. chect the thermostat.
  • 2,071 Answers
    Brigadier General:
  • 6,966 Answers
Pls check the freezer fan motor by pressing on the door button while door is ajar. Without letting go of the door button, the fan should kick in after about 15 seconds. You can verify the fan working, should be audible or you can feel air out from the vents. Pls be patient and continue pressing on the door button, the fan must not stop. If it does after a minute or so, replace the fan.
As to your query error code > freezer display flashes, normally it should be freezer coil defrost error, however, pls check if the flashing horizontal segment is the middle or the bottom; middle defrost error while bottom would be fan error.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 11, 2008
  • Louie  Role
    Louie Role Jul 16, 2008
    Hi again,
    As initially posted, pls change the fan.
  • Louie  Role
    Louie Role Jul 19, 2008
    The existing fan works intermittently. When the temperature go down, it will fail. The refrigerator then will slowly warm up (including the fan. The cycle begins again. It will run initially, then it will stop as the fridge gets cold. You can try cleaning/lubricating the inside of the fan motor but that is a temporary/stopgap. I is relatively low cost and for all the trouble of opening the panel to gain access to clean, you might as well just replace the fan.
  • 4,472 Answers
Also to make sure the back of the fridge isn't too close to the wall by chance? This can cause problems and could be what caused this problem.
Thanks,
Lee
  • Lee A.
    Lee A. Jul 11, 2008
    Then I would most likely say it is the control board. Are you attempting to service this yourself? I would recommend a qualified technician I can assist you in finding one with your zip code.
    Hope you find this helpful.
    Thanks,
    Lee
  • 4,889 Answers
Your issue can be explained by a faulty defrost timer which is causing the temperature to vary inside the refrigirator. When you unplug and plug it back in the circuit will be reset and hence it works correctly. The faulty display temperature can be explained by a faulty control board. Repairs Should run you about 300$ for the parts. If you have good experience in dealing with electronic circuits then i can see you through this repair. Otherwise you will have to purchase the parts and get a tech to replace them.
Good Luck!
Sai.
Posted on Jul 10, 2008
  • 190 Answers
Dear Customer, Your fridge's Temperature controls maybe faulty and require replacements. Howevr before replacing the refrigerator's temperature controls, you should do some basic troubleshooting to make sure the problem stems from a defective control and not some other problem. The most obvious thing to check is that the refrigerator is plugged in and receiving power from the outlet. If it is running, but not cooling, it could be due to dirty condenser coils or a defective door seal. Once the coils are clean and the door seal has been checked, you can be pretty confident that the problem is the temperature controls. There are usually two control knobs, one that controls the temperature of the freezer and one that controls the refrigerator. Although they appear to be independent controls, it is important to understand that the cold air comes solely from the freezer area into the refrigerator compartment. The freezer control determines how much cold air the condenser produces while the refrigerator control adjusts the flow of cold air from the freezer to the refrigerator compartment. If there is no cold air on either side, it is probably the freezer control that is at fault. The procedure to replace the control switch is the same for the refrigerator control and for the freezer control. Even though we have gone through this troubleshooting, it is still a good idea to test the control mechanism before replacing it. You will need a multitester and possibly needle-nose pliers and a screwdriver for the testing. First, unplug the refrigerator so you don't get shocked. Then, remove the temperature control's dial and/or housing. The dial will just pull straight off, but the housing may have screws holding it in place. After removing the housing, just let it hang by its wires. There should be two wires attached to the control. Label them before disconnecting so it is easier to put back together. Remove the wires by pulling on the slip-on connectors, not the wires themselves. Needle-nose pliers may be needed to remove these connectors from the terminals, especially if the refrigerator is old. Set the ohms setting on your multitester to X1 and attach one probe to each terminal. Turn the temperature control to off or to the warmest setting if there is no off position. The multitester should give you a reading of infinity if the control is on off and a reading of near infinity if there is no off position. Then turn the control to the coldest setting and retest. Now, the multitester should give you a reading of zero. If both of these tests are not passed, the control needs to be replaced. You already have the dial part of the temperature control disassembled, but there is also a temperature probe attached to it. Remove all fasteners holding on the existing probe and take note of the path of the probe. Install the new temperature probe along the same path as the original. Do not bend at a sharp angle and try to avoid bending more than necessary so the probe does not get damaged. Attach the refrigerator's wires to the new temperature, replacing the connectors if corroded. Replace the switch and any necessary housing screws you removed earlier. Plug in the refrigerator and set the temperature control to the midpoint setting. The refrigerator should start cooling down within one to two hours. This should solve the problem. Please rate this solution.Thank you..
    Scholar:
  • 135 Answers
Dear customer
Thanks for ur enquiry,it seems
  • Oven sensor is FUBAR. You’ll need to ohm it out using a good digital ohmmeter.
  • Thermostat is fried.
  • Check that oven door gasket for rips and tears. That’ll do it,
  • thanking u
      Master:
    • 382 Answers
    this is probably a problem with ur thermostat which is due to the overflow of current which has affected the display of current temperature!..so please call service person for assistance ,which can be corrected easily by replacing the circuit.Also dont forget to claim your warranty.Hope this helps you.please dont forget to rate the solution..Thank you!!..
    • 813 Answers
    Hi firend
    u shoud call a compney service man if u try to riper it most of probelity u have damged your refzratior if u call a good technision of refzartior its will be good for u & your product so call the thchnision
      Genius:
    • 1,665 Answers
    WHAT IS WRONG WITH YOUR REFRIGERATOR?
    http://www.repairclinic.com/0088_4_1.asp
    BXA2G oven is not heating properly and also air-flow on display board is not stablising and also both set temperature and oven temperature is flashing.so can you email me aa manual please
    Your temperatures will begin flashing after the oven attempted to heat for 10 minutes without successfully increasing in temperature. Sound like you are having burner issues and should call a licensed burner technician to have it serviced.
    Aug 05, 2011 | Baxter BXA2G Stainless Steel Gas Single...
    How do I change the temp fro m degrees C to degrees F? I have a Accubake System single oven. Thanks!
    From Page 15 of the Manual:
    Press and hold the "Custom Broil" pad for 5
    seconds. A short tone will sound
    NOTE: The temperature display will go off
    and the temperatures displayed will
    after a conversion. The temperature display
    be converted. To switch back to "F, repeat the instructions above.
    NOTE: The temperature display will go off after a conversion.The temperature display will reappear the next time you press a cook function command pad.
    Jul 16, 2011 | Whirlpool RBS275PD Electric Single Oven
    Aeg b5741-14 oven has code f5 -what does this mean?
    Here is a list of oven error codes for your model Kenmore oven.
    1. F0 indicates a Stuck key pad.
    2. F1 and F7 may mean relay is turned on.
    3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
    4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
    5. F5 indicates a loss of relay drive circuit.
    6. FF indicates a loss of door motor safety switch.
    7. FC indicates a door lock circuit problem.
    If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
    If the problem repeats, call for service.
    Jul 16, 2011 | AEG B5741-4 Electric Single Oven
    HOW TO ADJUST THE OVEN THERMOSTAT ON A WHIRLPOOL GAS OVEN MODEL SF387PEYQ7. THANKS AJ
    Press and hold BAKE pad for five (5) seconds. Current offset, if any is shown in 3-digit display. CAL is shown in 4-digit display (3 digits on right).
    Pressing the UP pad adjust the temperature in 10 degree F increments in fthe following sequence: 0, 10,20,30,-30,-20,-10, 0 and so on.
    Press START/ENTER pad to activate the desire tempature adjustment. If the START/ENTER pad is not pressed within 5 minutes, adjustment is ignored.
    May 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    General electric spectra oven F2 problem
    Replace the temperature sensor.
    Mar 21, 2009 | GE Ovens
    Oven temperature only gets to within 20-25 degrees of temp. set
    next to last page in your manual
    Adjusting Oven Temperature
    Oven temperature has been factory calibrated and tested. If
    oven consistently over or under cooks food, adjust thermostat.
    Oven temperature can be increased or decreased 35°F. To
    avoid over adjusting oven, move temperature 5°F each time.
    1. Push BAKE pad.
    2. Press + pad until an oven temperature greater than 500°F
    shows in display.
    3. Immediately push and hold, approximately 5 seconds,
    BAKE button until “00” appears.
    4. Press + or - arrow pad to adjust oven temperature.
    • To increase oven temperature (for a hotter oven), Press
    pad until a positive number appears in display.
    • To decrease oven temperature (for a cooler oven),
    Press pad until a negative number appears in display.
    5. Press OVEN CANCEL pad to save adjustment.
    • Setting is saved if power fails or is disconnected.
    heres a link to the entire manual if needed
    http://shop.amana.com/assets/pdfs/literature/32103601.PDF
    Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
    Maytag MER5775QAS
    Could be a couple things. If your machine is actually failing either a control board or an oven sensor.
    Also measuring the temperature can only be done by a tech unless you have a special tool. Oven thermometers are inaccurate. Plus most ranges should vary temp between 50-75 degrees unless has a feature or the more recent ones keep it between 15-25 degrees.
    Try the biscuit test, buy some biscuit, brand not important, i just say pillsbury. Cook exactly as recommended on package. If results are a little overcooked or a bit undercook try a feature called Adjusting the oven temperature or Calibrating the oven. This can be done by following the instructions in your book.
    Maytag.com click support click manuals put in model MER5775QA (notice i took off your models S) open the Use guide, page 14
    May 01, 2008 | Ovens
    Kenmore electric oven
    Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
    Dec 02, 2007 | Ovens
    F3 code and beeping
    F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
    · contamination on terminals
    · pinched wire in oven temperature sensor circuit
    · cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
    · Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
    · Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
    · Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
    If all above is ok replace control.
    Nov 17, 2007 | GE Profile Advantium SCB2001KSS Stainless...
    Dimming temperature and clock light on display window
    I found capacitor c3 (68 uf 35 volt) had leaked and dried up, causing the display to fail. I unsoldered and tested c1, c4, c7, and made sure they were good, using a digital multimeter with the ability to test capacitors. C3 also had visible signs of leakage. Works like a charm again, and the display is bright like new!
    Dec 30, 2006 | Thermador SC272T Electric Double Oven
    Ovens Logo
    919 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
