Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool Side by Side Ice Maker Not Making Ice
After removing the ice bin to fill a cooler, my ice maker won't make ice anymore. I've checked to make sure there's no ice blocking the chute and I've replaced the ice bin several times to make sure it's in place. There is an infrared sensor for auto shut off and that is clear and in the on position. Any suggestions?
  • 1 more comment
  • Anonymous Jul 22, 2008
    my ice maker quite making ice. i have done nothing. thanks
  • lauren24 Jul 26, 2008
    Where is the filter and how do you change?
  • tmaxwell834 Jul 29, 2008
    Ice maker quit making ice, after I replace a new filter, and sensor light is blinking, please advise.
    Thanks
I also have like a snow build up inside the freezer.
Posted on Sep 22, 2008
If you have the type of ice maker that has an ice bin on the freezer door, then there are instructions available at www.AnyoneCanFixIt.com to fix the ice maker problem. They also sell the part that is sometimes required to repair this common problem on the ice maker. The problem is notorious on these refrigerators that were made around 2004 and later. The ice maker will usually go out within 1-2 years. They have redesigned a part to eliminate the problem.
Posted on Jul 31, 2008
    Sergeant:
    Champion:
  • 330 Answers
Sometimes if you use the water filer too long and don't change, can cause this problem.
Posted on Jul 10, 2008
Whirlpool gss26c5xyy ice maker not making ice, but will dispense ice and also will dispense water.
Andrea, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Second thing to check are your optics( It measures ice level in your bin. If they are defective it will trick your ice maker into thinking its full of ice and not produce anymore.) They are located on the freezer walls just below ice maker..
Good luck
Jul 08, 2017 | Whirlpool Refrigerators
Frigidaire Gallery French Door Refrigerator ice maker not making ice
You can search with your model number to see if a filter is available or not. Secondly unless the ice maker was damaged for sure it's likely that the fan is not running in that compartment or air is leaking into the refrigerator and making the ice maker think its not cold enough to make ice.
Apr 13, 2013 | Frigidaire Gallery 25.8 Cu. Ft. French...
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
I have a side by side refrigerator and ice maker will not produce ice anymore
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Apr 27, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not making ice,checked optics ,good ,water valve coil tested good, no restrictionsbut i get no water in tray,also freezer temp is 8 degrees.
OK you mentioned the ice maker had no cubes or not making cubes, try filling tray with water from tap. Let freeze and if the ice drops into ice bin the ice maker is OK. Most times the ice maker thermostat is at fault (pt. 27 in photo) if not cycling. Read OHM's between both coils and they should be very near to same reading, if not replace water control valve=> 4389177 by applying first 120VAC to see if valve opens. If water goes into ice maker this way or OHMs between the two are nearly the same your Ice Maker=>2198597 Ice Maker Assembly may need replaced. If you would like to rebuild your Ice Maker here are the part Breakdown view=>
GS5SHAXN Ice Maker Replacement Parts
Let me know how your ice or water turns out, Thanks Sea Breeze
Feb 11, 2011 | Whirlpool GS5SHAXN Side by Side...
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice Maker is not working on my Whirlpool Gold Refrigerator
I removed six screws from the ice maker to pull it out of the refrigerator.  Their are four screws holding the ice maker in place and two screws on the ice maker door.  Had problems getting the electrical harness disconnected.  Used hot water to removed the ice cubes that were struck in the ice tray.  Poured all remaining water into a bucket and re-installed ice maker.  As of now, the ice maker is making ice !
Apr 08, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Stop making ice
check if there is ice in the ice maker, see if there is water coming in to the ice maker. maybe a water problem or a solenoid problem...if there is no ice in the ice maker...try to pour manually a cup of water on the ice maker and empty the ice bin so that you can observe if the ice maker is working if there would be ice in the bin after an hour. if there is ice, then a water problem is most likely to look at. i hope the freezer is working perfectly..
Feb 11, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
1,211 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
