Hello My hot water heater suddenly has earth lekage. What could be the problem.
    Problem Solver:
  • 15 Answers
The element will probably need replaceing real soon now....
Posted on Jul 10, 2008
Why does the water suddenly runs COLD after many minutes of running hot?
Unless you are using a tankless hot water heater, there is a limited amount of hot water available in the tank. Electric and gas water tanks need time to recover after use, and if you are using heavily, it can exhaust the available supply. That said, there are a couple reasons why you may have less hot water than seems normal. In both electric and gas water heaters, silt can form in the bottom of the tank. This will build up over time and displace water. It also reduces the heating efficiency of gas units. There is a drain valve on the bottom of water heater tanks to allow for purging of this silt periodically, but few ever do it. You could also have, in the case of an electric hot water heater, a bad element or thermostat. Most electric heaters have an upper and lower element and thermostat. If one fails the other will still work, but the water takes longer to get hot and will deplete faster.
Nov 04, 2015 | Water Water Heaters
How can I troubleshoot and fix my gas water heater?
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Troubleshoot by type of gas control valve
Check if you have water leak running hot out of tank.
Check for crossover.
http://waterheatertimer.org/Crossover.html
Gene
Nov 12, 2014 | Water Heaters
I have two wires going to my hot water heater red and black but no ground but the inspector says i need to connet a ground line toi the green screw on the electrical pannel on the top of the hot water...
It is the same as all the other appliances in your house, they should be earthed (grounded). You can run a new earth wire from the meterbox to the hot water heater or pick up an earth anywhere in the house and run it to the heater. The earthing conductor connecting to the hot water heater should be the same size as the active and neutral conductors or no less than 2.5mm square.
Feb 14, 2011 | General Electric Water Heaters
Hello we have Bradford hot water tank model #MI65R6DS13. Our problem, I keep having to press the tanks reset switch for us to get hot water. At the same time after I press the reset switch we have hot...
No the top thermostat is the first place I would start to replace. They run about 14.00 more than likely it isn't controling right. Turn power supply to water heater off and replace thermostat.
If you was getting scalding hot and then turning cold without tripping the thermostat it would be the top element working and the bottom one bad.
Bottom element good it will give you luke warm water for a while then gradually turn cold because it's heating the bottom of the tank.
Hope this will help you out.
Oct 09, 2010 | Fasco Bradford White Hot Water Heater...
I have replaced my electric water heater and I have checked everything I can think of and I still run out of hot water in 3 minutes. What on earth is the problem.
3 minutes?? does the water run cold then? or just warm?
Is this what the tank you replaced was doing? If so, then you may have: 1 a recirculating pump instant hot water system thats faulty and allowing cold water backflow into hot water piping. 2 A tempering valve that has stuck, allowing cold water into your hot water system.
Or maybe a broken or missing dip tube in your new heater.
If after 3 minutes the water is coming cold out leave that faucet running and go to heater and feel the hot water outlet pipe from the heater. if that pipe is hot then the heater is not the problem. If the hot pipe from the heater is cold the heater is the problem. (Make sure the cold pipe coming into the heater is connected to the Right side marked "cold" !) If there is a tempering valve by the heater: feel the output from the tempering valve, if it is cold and the pipe from the heater to the tempering valve is hot, then the tempering valve is the problem. If all these are OK somewhere in your plumbing system hot and cold may be connected possibly a faucet or showerhead that is shut off at the spout/head, but hot/cold handles are left turned on then cold water can backflow thru hot pipe.
Jan 18, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
