YES! If you will type in "Sears Parts" you will be given a place to enter your model number. I tried it and it came up as"not a good number". You try it. That web site has complete diagrams for all machines. Be blessed.
this link http://www.repairclinic.com/Dryer-Belt-Diagrams is belt configuration of all different brank dryers,The roper is either going to be diagram H or K refer to chart to see which yours will be based on the back panel
What I would do is pull the dryer out and unplug the power cord. I would remove the rear cover and check the components back there for continuity.If all of that is good then the timer or breaker might be bad. Why? The timer calls for heat through the RH leg. The amp draw from the heating element arcs up the contact point inside the timer. The motor runs on 120 volts the heater runs on 240 volts. So the breaker will take a beating on the heater side of it. The dryer will hower still run. To recap It could be the heater the limits the time or an electrical problem. Rate it or Hate it:
Usually a little less than half of original price paid as new, on working appliances, that is. I would advertise the bad one as free, with the purchase of the running one. You should do well with these on craigs list.
Most likely a broken heater coil wire. It is common. When you open the unit up you can easily see if this is the problem. It should show a damaged section
