Question about Toshiba Satellite A135-S4527 Notebook
Notebooks when removed from power laptop gets switched off lithon battery new one (satellite model)
Did not fix it. I even reinstalled drivers for battery and adapter in device manager. I cannot belive so many other users are having this same problem with various other manufacturers. I see a trend with Vista users. Is it possible Vista is doing this.
Posted on Sep 18, 2008
Did not help
Posted on Sep 01, 2008
Did not work for me. I bought a new charger and a new battery and neither fixed the problem. Dometimes the battery will charge and sometimes it will not.
Posted on Jul 23, 2008
    Sergeant:
  • 264 Answers
Well it surely shows that the battery is not providing backup to the laptop. There could be two reasons for the same
1. The battery is not compatiable.
2. Defective and faulty battery.
However i will give you a step which you should try once and see if it makes any difference.
Method (Power cycle)
You need to remove the battery, adapter and any other device connected to the computer (May be any additional cards or any wires as for Ethernet or speakers or external mouse/keyboard).
Nothing should be connected at all.
Now Press and hold the power button for 25 seconds (It wont show anything). This is a step to release any static charges developed, which may surely caused the kind of issue you are facing.
Now connect the battery and the adapter and check whether it is charging the battery and provides you the backup.
Please let me know what happens.
Regards
Sammy
Posted on Jul 10, 2008
Clear cmos toshiba laptop satellite L35-S2174
Remove coin battery for 2 minutes, Computer will default to original new computer status. Make sure the 2032 coin battery is good.
Dec 26, 2012 | Toshiba Satellite L35-S2174...
I want to update the bios on toshiba satellite a10
Go to Toshiba support website and enter your computer model no. to get new driver, there may be a Re flash of Bios available.
Oct 10, 2012 | Toshiba Satellite A10-S100...
I was in facebook playing farmville, when suddenly the screen of my new laptop(toshiba satellite A660/07R)hung.i have no choice rather to power it off. when i switch back on,the screen flashes different...
With an extensive use of the notebook,
some times notebook would store some static charges which
indeed will stop the notebook from powering up or charging
the battery. The procedure to remove this static charges from
the notebook is known as power drain. Performing a power
drain procedure will not effect any personal data or delete
any pictures from the hard drive on your notebook.
I recommend you use Power Drain procedure by following these
steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Dec 12, 2010 | Computers & Internet
Toshiba Satellite P205d S7479 shuts down suddenly when on battery. The battery is brand new.
Try to turn off the laptop
Remove cables and battery on the pc
Press and hold the power button for 5 seconds
reinsert battery and cables on the laptop
Turn on the laptop
Check if the PC still shuts down. If it is, try to connect the power cable without the battery. If it turns on, call your pc manufacturer to replace the battery....
Jun 21, 2010 | Toshiba Satellite A135-S4527 Notebook
I have a satellite pro 300 that wont charge the new battery .Can u help?
Remove the DC cord, and the battery reinstall the DC first and switch on the laptop and then install the battery carefully while its switched on.
Apr 01, 2010 | Toshiba Satellite Pro L300 Notebook
New battery for toshiba laptpo 4600 but stillnot holding charge
Two options, though check your user manual (if you have one...):
1) Many modern laptops work fine on mains power without the battery installed. So try removing the battery and switching on just with mains power. And when you switch on, press the on/off switch hard.
2) Many laptops have a reset switch. Sometimes this is somewhere around the keyboard (you may need a needle - the blunt end!! - or similar to press it) or possibly under one of the removable covers on the underside.
Jun 24, 2009 | Toshiba Satellite Pro 4600 Notebook
I have a toshiba laptop computer satellite a215-s4807. I cannot get it to power on. The battery went completely dead and I plugged it in to charge. But it will not power on with it plugged into the wall.
have you tried before to reassemble your laptop? if not...dont do that...because it will damage your laptop..if YES....open the laptop...remove the motherboard and replaced the power jack of the motherbaord...be sure that you find same model of the jack....if you find desolder the old jack and solder the new jack and return to assmble you laptop and put the charger and power on...good luck am 100% it will work..because this is my job..if still not work..dont hesitate to contact me..
Dec 15, 2008 | Toshiba Satellite A215-S4807 Notebook
Satellite A100 won't swich on- will be similar to A75
remove the battery , then insert it again, then leave it for charging for some times then check
Oct 26, 2008 | Toshiba Satellite A75-S209 Notebook
Toshiba laptop power light on but not working
Try this.Your VGA is problem or your battery is fully charge down.so please fully charge your battery atleast 8 hours and then press your power switch.it will on your loptop system.
plz Call 09944377607 V.RAJA
Jul 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
47 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
